You may not have the same problem as I did with the RPM intake here in QLD ,but I had to fit a half inch heat spacer between the intake and carby . Also if your engine is fairly stock , revs under 5,500 rpm I would fit a spacer with the 4 holes ,it will give the engine a lot more torque .
