Author Topic: What did you do for your Mustang today?  (Read 656760 times)
« Reply #450 on: August 10, 2013, 10:12:38 pm »
Yes, going in the old girl and the 4 speed auto.
Its a bitsa, falcon engine with a mix of mustang gt and explorer components.
Will be using the ford ecu with some extensive remapping.
Peter.
A mate is running one with a Mega squirt ecu, with the auto from an NC Fairlane the engine came from, some of the early 4 speeds have a stand alone ecu, just needs TPS signal. He did not use the original air ram, but rather a throttle body under a factory air cleaner, so it looks kind of stock still multi point  injection though, modified the injection lower manifold to suit the throttle body. Seems to go ok.
« Last Edit: August 10, 2013, 10:15:08 pm by shaunp »
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #451 on: August 10, 2013, 10:32:36 pm »
No, ported e7 heads with 1.7 roller rockers.
Peter.
Offline peter9231
  • Name: Peter
« Reply #452 on: August 10, 2013, 10:37:41 pm »
Wanted to stay with the ford ecu.
Once you change the "Look up tables" they are a very good ecu.
Running explorer intake, similar to AU but with more flow.
Explorer throttle body, again bigger than AU
Genuine ford ( Crane roller rockers) 1.7:1 ratio.
95LE auto.
Peter.
« Reply #453 on: August 11, 2013, 10:16:21 am »
HO cam, I guess with the 1.7s? That should wake it up a bit they make good power. I'm going to put mine together this week, painted the inside of the block last night, about to go and give the outside a hit of 2pack shortly. I'm using some AFR Outlaw alloy heads, and reasonable sized Comp Cam extreme energy roller cam with some Scorpion roller rockers. I've got a set of 1.7s comp cams rockers, from another engine, but the valves will be getting close to the pistons on this cam I think, and I don't want to move the power an higher up the rev range, I'll check the clearance when I build it, may try the 1.7s later for an experiment. Not running injection, but and RPM Air-gap and Holley avenger. Got some RHD Hedman ceramic coated 4 into 1 headers, from Sydney mustang supplies. Hopefully it will be a pretty twisty engine.
Offline birdman
  • Name: John
« Reply #454 on: August 11, 2013, 03:54:16 pm »
I actually drove it last night and this morning.  :grin:
Offline peter9231
  • Name: Peter
« Reply #455 on: August 11, 2013, 04:29:48 pm »
HO cam with 1.7 rockers were standard in the sprint engine in the falcon.
I am using flat tops with valve relief only, so that should get the comp up a bit.
I want the EFI and electronic 4 speed auto.
Peter.
  • Car: 1969 Shelby GT500
« Reply #456 on: August 11, 2013, 05:32:46 pm »
Got the footwell light working. Had trouble getting the globe in which was frustrating so had to take the glovebox out and undo the light bracket to do some work on the light fitting to get the globe in. All good now.
Offline Herman
  • A bit of concours nutter, but I'm still learning!!
« Reply #457 on: August 11, 2013, 05:56:59 pm »
I simply looked at mine and said stuff it I'll do that another day  :lol:
Have now converted the other half into doing some of the Concours washin, cleaning & polishing stuff!!!!!!!!
« Reply #458 on: August 11, 2013, 08:18:34 pm »
Prepped my block prior to engine build, Had the shop hone, deck, hot tank, and replace cam bearings, I opened up oil drain backs drilled and tapped lifter valley for roller cam spider, chased all threads, 2 coats of black 2 pack on the outside, Glyptol on the inside
« Last Edit: August 11, 2013, 08:21:58 pm by shaunp »
Offline peter9231
  • Name: Peter
« Reply #459 on: August 11, 2013, 09:01:51 pm »
Finished fitting most of the hang on accessories.
Peter.
Offline boss69hogg
  • Name: David
« Reply #460 on: August 16, 2013, 04:00:08 pm »
Picked her up from the mechanic another thousand dollars poorer with the news that the oil leak is bigger than we thought and will require the engine to be pulled from the car! At least he has fixed the sway bar bushes that were the wrong ones, fixed the fuel mix, set the timing right (off 30 degrees), gave it a f
Good service and fixed various other things that were questionable!
Thankfully he is an old family friend so I know he isn't ripping me off.
Offline MJ Stang
« Reply #461 on: August 16, 2013, 07:08:25 pm »
Got my mistress a green slip and registered for another 12months  :grin:
1967 convertible C code...my mistress :)
Offline peter9231
  • Name: Peter
« Reply #462 on: August 16, 2013, 08:02:09 pm »
Finished assembling all the wiring, fuel components and completed all the fiddly bits.
I also rebuilt the auto this week and reattached it to the heart.
Been a busy week, but enjoyable.
Peter.
Offline GT350H
« Reply #463 on: August 17, 2013, 08:42:40 pm »
Oh, nothing much - JUST BROKE A WORLD RECORD !!!
Not me, but Moits Racing..I was there  :thumb:
In Sydney - today
https://www.youtube.com/watch?v=Wq_uAd6cjB4&feature=player_embedded
AKA Emberglo-66
Offline boss69hogg
  • Name: David
« Reply #464 on: August 18, 2013, 02:04:30 pm »
Met up with my Ncle and his 02 Cobraconvertible and went for a nice cruise through the valley and up to the Corrugated Cafe at Peats Ridge for a big bacon and egg breakfast and a couple of happy snaps of the girls!
Offline mustang_talk
  • Name: George
« Reply #465 on: August 18, 2013, 06:59:41 pm »
I took out the rear seat, considered were I could add anchor points for seat belts, put the seat back and went for a cruise.
« Reply #466 on: August 18, 2013, 07:04:52 pm »
I bet the cars got some attention
Offline GT Sally
  • MOCA NSW member since 2008
  • Name: Gazza
« Reply #467 on: August 20, 2013, 09:27:51 pm »
Just drove it again after 2 days of clay blocking & waxing, approached by a guy at the local drive thru dry cleaners who has been itchin' to meet me & has been checking out my GT, he & his daughter have seen me cruisin around quite alot (possibly on my way to Sydney mustang Parts), they live close by, he knew where I lived coz his daughter saw me pulling in the drive, thats scary....he wants to buy a toy, not getting mine... :lmao: it's such a buzz when a stranger appreciates ur ride, I've had guys take fotos at traffic lights of my ride, I'm sure it happens to all of us
If you haven't grown up & matured by the age of 55, (65 now & nothin has changed) YOU DON'T HAVE TOO.....Gary
Offline Ash
  • Name: Max Power
« Reply #468 on: August 20, 2013, 09:29:50 pm »
Even better when the girls are waving to you and their boyfriends give you a dirty look  :lmao:
Offline GT Sally
  • Name: Gazza
« Reply #469 on: August 20, 2013, 09:34:26 pm »
had a woman pull up beside me at lights, wound the passenger window down where her teenage daughter was sitting, asked if she could swap cars, her daughter gave me the most filthy look I ever saw....
« Reply #470 on: August 20, 2013, 09:36:23 pm »
GT SALLY ,YES PEOPLE TAKE PHOTOS OF MY MUSTANGS ALL THE TIME AND ASK IF I WILL GET OUT OF IT  SO I DONT SPOIL THE PHOTO .  :grin: :lmao: :lmao: DOEST SOUND LIKE THAT HAPPENS TO YOU . :grin:
Offline Ash
  • Name: Max Power
« Reply #471 on: August 20, 2013, 09:37:31 pm »
Hahaha, that's great!
Offline GT Sally
  • Name: Gazza
« Reply #472 on: August 20, 2013, 09:42:46 pm »
at 62 with a shaved & not so pretty head, they don't have the balls to ask.....I have been tols I look like Angry (Gary) Anderson & Gary Sweep not to mention Bruce Willis
« Last Edit: August 20, 2013, 10:04:29 pm by GT Sally »
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #473 on: August 20, 2013, 10:24:14 pm »
Ha! i pulled up at the shops on weekend and this tidy woman said "oh thats as sexy as it gets!"
couldnt resist batting straight back to her "yeah thanks, and so is the car"
mustve been the 'sex panther' i had on.... :lol:
you get that .....
Offline Ash
  • Name: Max Power
« Reply #474 on: August 20, 2013, 10:26:41 pm »
 :lmao:
60% of the time, it works every time.
:pepper:
