302 BLOCKS HOW STRONG ??????
Author Topic: 302 BLOCKS HOW STRONG ??????  (Read 2970 times)
Offline whiplash
« on: June 14, 2008, 10:28:35 am »
Ok I've been hearing around the traps that the 302 windsor blocks ( late model ) 1990 onwards.... roller blocks are only good for roughly 500hp at the flywheel with a stud girdle .
Does anyone know weather this is true ;w
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
    • www.CustomMustangs.com.au
« Reply #1 on: June 14, 2008, 12:30:55 pm »
I have heard similar, I wouldn't use a factory block, given the choice, anyway.
I would buy a Motown or Dart block in 8.7" deck height, and build a 289 size 3800+ cube engine, or step up to a 351w sized 9.5" deck block, and build a 427 - 460 cube motor. I wouldn't mess with a 8.2" block, or a standard ford block, given the choice.
I regret not doing it in mine, I bought the stroker first, and had to go very long stroke.
69mach1 has a 427cube small block, he probably has a 4.17" stroke, with 4" bore, but with aftermarket blocks, you can go 4.125" bore, and shorter stroke, and keep the revability AND cubes!
Custom Mustangs
0438 351 400 or 03 9782 8850
For Email CLICK HERE
Signature Sponsor
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #2 on: June 14, 2008, 05:59:25 pm »
Originally posted by 69mach1
I'd agree and go aftermarket block.
I went with the 9.5" DART block, 4.125"bore and 4.0" SCAT crank, engine makes good torque and HP.
mmmm..... thats what I missed out on, silly me bought the stroker kit first....
You still have room to bore further, and stroke longer.... my brother has 460 cubes in his windsor ;x
Custom Mustangs
Signature Sponsor
Offline whiplash
« Reply #3 on: June 15, 2008, 03:07:51 pm »
Thanks guys my minds made up !!!! Either a World Industries Man o war Short motor or I'll start with a Dart block and Forged crank :(
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #4 on: June 15, 2008, 06:43:38 pm »
My brother bought the World 460 short, and is going to change pistons and fit a set of AFD's, and run methanol injection for a drag motor. The pistons aren't world class, but would be OK in a streeter.
I bought my stroker kit thru Haddad Race Cars, and got a Forged steel Scat Crank, Steel H beams, and Arias pistons for about $3500. I could have bought the cast crank (a friend has one in his Cortina street car, runs 9.0's on street radials, should be running 8.60's with tuning) and cheaper pistons for a lot less.
Custom Mustangs
Signature Sponsor
Offline whiplash
« Reply #5 on: June 19, 2008, 06:56:03 pm »
DART BLOCK 31384175  ORDERED AS WELL AS A FORGED CRANK !!!!!  :(
Offline BLKPNY
  • Pegasus
  • Forum Sponsor
« Reply #6 on: June 19, 2008, 07:57:30 pm »
Nice work!!
What bore and stroke have you chosen?
Custom Mustangs
Signature Sponsor
Offline whiplash
« Reply #7 on: June 28, 2008, 06:40:33 pm »
Combo will consist of Dart block , 347 forged bottom end , solid roller cam , 8.0:1 comp or lower , Edelbrock VIC JNR alloy heads , wieand 177 supercharger kit  ect
should make a nice lil streeter :(
Offline nassi
« Reply #8 on: June 28, 2008, 08:37:58 pm »
Guestimate of cost for someone like me?????
cheers
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline whiplash
« Reply #9 on: June 30, 2008, 03:09:08 pm »
Roughly $25-30,000 :(  for me thats including gearbox, hi stall and ign sys
Offline nassi
« Reply #10 on: June 30, 2008, 03:42:34 pm »
FMD, I just lost interest in performance. Think I'll stick to classic :+
cheers.
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline pegasus
« Reply #11 on: June 30, 2008, 07:53:49 pm »
:f  He He He, I don't feel so bad about how much I spent on my motor now...I stopped counting at $20.K
With enough Time and Money almost anything is possible
Offline Muzzy 66
« Reply #12 on: July 01, 2008, 07:10:40 pm »
Its even worse when there sitting beside Chev stuff..:w:[
About 40% cheaper...:-
Growing old is inevitable, growing up is optional.
66 Muzzy Coupe
Offline nassi
« Reply #13 on: July 02, 2008, 09:24:08 am »
:i
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
