Distributor Gear ?
Author Topic: Distributor Gear ?  (Read 10006 times)
Re: Distributor Gear ?
« Reply #25 on: September 15, 2018, 04:25:05 pm »
To get the distributor to fit just grind the end of the shaft down, works a treat..  :lol:
Then superglue it in place.  :lmao:
Offline J.hatzivalsamis
  • Name: jimmy hatziv
« Reply #26 on: September 17, 2018, 11:57:24 am »
Barney the engine has not been fitted in yet I'm thinking 10w40 semi synthetic and I may look at the dissy gear that was on the block originally off EL falcon with roller cam. Thanks for the tip Fitzy i' fly you up here to do your work.
« Reply #27 on: September 17, 2018, 12:46:52 pm »
i would run full synthetic like the 10 10ths stuff. i hope you have a one piece rear main seal.
« Reply #28 on: September 17, 2018, 12:48:58 pm »
He's pretty good with a bench grinder now!  :bolt:
« Reply #29 on: September 17, 2018, 12:51:24 pm »
...and so is his ex "professional" engine builder. You should see the incredible job he did on fitzy's purportedly brand new distributor to get it to clear his intake.
OMG...I think I justn peed my pants!
:lmao:
« Reply #30 on: September 17, 2018, 01:15:00 pm »
Factory Bosch one will be steel
Offline Fitzy1980
« Reply #31 on: September 22, 2018, 03:37:39 pm »
I've been under the car so much I wore the wheels off the creeper...  :lmao:
« Reply #32 on: September 22, 2018, 03:49:37 pm »
After your last post, under the car sounds like the safest place for you!  :lmao:
« Reply #33 on: September 22, 2018, 04:11:58 pm »
With that possessed car, I wouldn't be climbing under it!!!!!!!
Offline HEVEN67
« Reply #34 on: October 26, 2018, 12:09:19 pm »
hi Folks
My general rule is steel cams need a steel gear cast cams need a cast gear, I put that question " can I use a cast mellonised gear on a steel billet cam?"to a cam manufacturer recently and they replied, no you should use a steel gear, and the cam manufacturer was Camtech Cams.
Luvhev
« Reply #35 on: October 26, 2018, 01:36:28 pm »
hi Folks
Luvhev
They need help. A melonised gear is steel, and yes, you can most certainly use it on a billet steel cam, at least you can use the crane one on them just like a bazillion other people have for the last bazillion years.
Offline JET445
  • Name: John
« Reply #36 on: October 26, 2018, 08:42:56 pm »
Yeah those ancient cavemen swear by mellonised cam gears :grin:
« Reply #37 on: October 27, 2018, 01:04:11 am »
Yes, even fred flintstone had one.
« Reply #38 on: October 27, 2018, 11:36:01 am »
You forgot to mention to grind the housing away for intake clearance too...or maybe that was for additional cooling.  :lmao:
