Back again, Have been going through the joys of degreeing? (is that even a word) my cam, now the crank gear has several key ways cut into it, at 2,4,6 and 8 degrees, both advanced and retarded, l have set the crank gear to 8 degrees advanced and still have only got to 102.5 lobe centre line,
Target figure is 106, it seems like such a large adjustment from the original line up dots, and still need more,does this sound right to anyone, does the rest of adjustment have to be done by rotating the crank gear one chain link at a time? have checked the lobe lift and it is within 0.002" so am confident the cam is correct, timing set is a rollmaster, am done for the day, my brain is fried, as usual any thoughts much appreciated..,
