Engine rebuild
Author Topic: Engine rebuild  (Read 58986 times)
Re: Engine rebuild
« Reply #200 on: August 26, 2018, 08:35:07 am »
Make sure you drill a hole in the gallery plug behind the disy gear
Re: Engine rebuild
« Reply #201 on: August 26, 2018, 09:27:46 am »
...before you install it.  :smile01:
i put them in the other lifter galley plug on the other side also.
i use a .020" (.5 mm) bit
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #202 on: August 26, 2018, 09:39:33 am »
Bored and honed, Tunnel honed to suit ARP mains bolts, one piece rear seal, zero decked, clearance ground for stroker crank,balanced 0.4gm
oil gallery plug hole drilled, (one side), Why the other side?? Cam bearings fitted, new welsh plugs and all bolt holes retapped, l think thats about it
for the block..,Can't wait to start putting it back together..,
Re: Engine rebuild
« Reply #203 on: August 26, 2018, 11:39:18 am »
the more oil on the cam chain the better, plus it helps lubricate the thrust surface between the cam and the retaining plate.
« Last Edit: August 26, 2018, 11:41:12 am by barnett468 »
Re: Engine rebuild
« Reply #204 on: August 26, 2018, 11:44:13 am »
oh wait...can we turn this into an ol thread now too!  :thumb:
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #205 on: August 26, 2018, 05:27:03 pm »
Why??  Are you quietly expecting this rebuild to turn to sh*t.., :lol:
Do beg my pardon, what is "ol"?
« Last Edit: August 26, 2018, 05:33:11 pm by Reborn67 »
Re: Engine rebuild
« Reply #206 on: August 26, 2018, 05:53:38 pm »
one hole is fine thats all I drill its the disy gear you want wet and believe me heaps of oil comes out of that hole.
Re: Engine rebuild
« Reply #207 on: August 27, 2018, 10:20:19 am »
My us to australian translation book says it is the ozzie word for "oil" so i was just tryin to speak your language.  :lmao:
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #208 on: August 28, 2018, 10:21:53 am »
 Question time again,  have purchased a set of Wiseco forged pistons, now there is no markings, dots, arrows on the tops to indicate piston orientation,
 And there is valve relief machining grooves in the tops on one side only, am assuming these reliefs go to the intake/valley side of the cylinder, so once assembled all reliefs should be pointing to the centre of the engine,
 Also with connecting rods (scat I beams) the Larger chamfer goes to the crank journal side and the lesser chamfer side goes against it "paired rod"
 even if the markings on the mains ends dont match the markings on its "paired rod" if that makes sense, l am not talking about rod and caps, they are numbered and you cant possibly get them wrong, Am l correct??
Re: Engine rebuild
« Reply #209 on: August 28, 2018, 10:24:13 am »
what is the part number on the pistons?
intake valve relief goes to the rear on the left side and to the front on the right side but it should have a relief for the exhaust too unless it is a boss 302 or 251 cleveland piston.
« Last Edit: August 28, 2018, 10:28:22 am by barnett468 »
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #210 on: August 28, 2018, 10:31:52 am »
 PTS511A4
Re: Engine rebuild
« Reply #211 on: August 28, 2018, 10:47:08 am »
looking now but can you photo of the top of them?
« Last Edit: August 28, 2018, 10:48:48 am by barnett468 »
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #212 on: August 28, 2018, 10:52:20 am »
Piston
Re: Engine rebuild
« Reply #213 on: August 28, 2018, 10:54:00 am »
Also with connecting rods (scat I beams) the Larger chamfer goes to the crank journal side and the lesser chamfer side goes against it "paired rod"... ...correct?
Yes
Offline Fitzy1980
Re: Engine rebuild
« Reply #214 on: August 28, 2018, 05:30:30 pm »
 :hello:  :hi:
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #215 on: August 28, 2018, 05:36:09 pm »
It's been a while, where have you been, and how's your little task going?
Re: Engine rebuild
« Reply #216 on: August 28, 2018, 07:05:12 pm »
So the rods, the fly cuts for the bearings go to the center of the engine thats it, this then will have the chamfer to the crank throw.
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #217 on: August 28, 2018, 08:13:31 pm »
 :thumb: :thumb:
Re: Engine rebuild
« Reply #218 on: August 29, 2018, 09:03:19 am »
Re: Engine rebuild
« Reply #219 on: August 29, 2018, 09:04:24 am »
Piston
Ok, those are correct and they mount the way I previously described.
« Last Edit: August 29, 2018, 09:09:51 am by barnett468 »
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #220 on: August 29, 2018, 09:59:31 am »
 :pepper: :pepper:
Offline Fitzy1980
Re: Engine rebuild
« Reply #221 on: August 30, 2018, 06:27:20 pm »
Did your pistons come with "custom" reliefs in the skirts ?  :lol:
Offline Fitzy1980
Re: Engine rebuild
« Reply #222 on: August 30, 2018, 06:27:58 pm »
He's ALIVE!
 :lmao:
That i am my friend...   :cheers:
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
Re: Engine rebuild
« Reply #223 on: August 30, 2018, 08:31:51 pm »
Too funny, Have lovely little radiused notches at the bottoms of the cylinder sleeves, neat and tidy, quietly impressed.., :smile01:
Re: Engine rebuild
« Reply #224 on: August 31, 2018, 02:22:42 am »
fitzy's builder let his pistons make their own clearance.  :lmao:
