Have a slightly worked (alloy heads, hydraulic cam, weiand stealth,750 vac sec) and have always had issues in traffic getting hot. Had a 3 core copper radiator with separate tranny cooler, big thermo fan, then went back to 7 blade engine fan with factory shroud but still had issues. I then bought a big aussie desert coolers one but have decided it is way to much work to fit with fact I am fitting A/C also so means modifying the bonnet latch to condenser installed. So have sold that radiator. Once car starts moving temp drops back down.
Was hoping to go one that will fit original mounts and bolt in. Are there particular ones to go for that you guys can recommend as doing a search comes up with so many options I get a bit lost?
Thanks in advance
