1983 Fox Mustang convertible (Export)
Author Topic: 1983 Fox Mustang convertible (Export)  (Read 5105 times)
Offline Elsey61
« on: January 29, 2016, 05:17:14 pm »
Hi Mustang owners,
I recently purchased a 1983 Fox Mustang convertible 302 with a 4 speed srod gearbox right hand drive .
Need help with researching some history on this as the Buck tag is stamped with Model Ex (Export)
Was it imported by a Ford dealer  ? Where do i start ?
Elsey61
  • Car: 1969 Shelby GT500
Re: 1983 Fox Mustang convertible (Export)
« Reply #1 on: January 29, 2016, 06:11:47 pm »
Welcome Brett. Start by running your VIN number through the VIN decoder at the link below
http://www.mustangdecoder.com/decoder.html
« Reply #2 on: January 29, 2016, 06:13:17 pm »
You can also order a Marti report online at the following link.
https://www.martiauto.com/reports2.cfm
Offline Ausfox
« Reply #3 on: January 29, 2016, 09:27:50 pm »
Hi Brett, good to see the Fox Body numbers boosted.
Is this the red Brisbane car?.
Surprised that the buck tag survived.
Your best site for info on an 83 is Four Eyed Pride Forum. There used to be a thread on deciphering Buck Tags.
http://vb.foureyedpride.com/
Does it still have the Vehicle ID Label?. Normally stuck on the left hand side B pillar door opening, should have a DSO code on it. Some of these codes can tell where the car was sent.
Apart from the Marti report, you can also get a Carfax or a Vinaudit online using the vin #, cost between $9 to $45US.
There is also an address you can write to For Ford records in Detroit which should have info if the car was exported.
Will see if I can dig it up.
« Last Edit: January 29, 2016, 09:30:17 pm by Ausfox »
17 SEPT 1964 FASTBACK
1966 Turbo 6Cyl Coupe
1979 INDY PACE CAR
http://s251.photobucket.com/albums/gg310/427gge/Mustang%20Pacecar/
Offline Elsey61
« Reply #4 on: January 30, 2016, 02:14:57 am »
Thanks Ausfox, Yes its the Red Brisbane car , now in Rockhampton.
I have posted on the Four Eyed Forum , used a link for Buck tag decoder which was helpful , details below .
Will check id label tomorrow
MUSTANG = Mustang model line
131039 = 31,039th 1983 Ford scheduled for production at Dearborn Assembly
CVT = Mustang 2-dr convertible
F = H.O. 5.0L V8 engine
277 = Bright Red exterior paint color
WHI = White convertible top color
DF
ST
PS
AC = manual air conditioner
01
EX = export
S = speed control (cruise control)
RM = rocker molding
DL = power door locks
MOD = manual overdrive transmission (Tremec 4-speed 'SROD')
01 = type of hood/scoop (unknown)
V = visibility (light group)
ELECTRIC
N = Opal and Medium Red interior trim color
