Ok check this budget semi stroker out which will have substantially more hp and tq . . it is far from a tire roasting high revving combo . . it will increase your hp and tq EVERYWHERE in the rpm range and it will only cost around $650.00 more than a box stock rebuild.
Go to a crank grinder and buy a pre 1984 302 crank . . it might be around $350.00 . . you can also look on craigs list . . might find one for $100.00 that needs grinding . . there should be several around because people yank them out to make strokers . . this will make it a 272 ci with a standard bore and a 276 with a .030” over bore.
your crank will need regrinding anyway so all you are out is around $100.00 for a used core 302 crank.
you may also find one if you place a wanted add on the forum for one or just start a thread in this section asking for one . . same with the rods . . glenn, shaunp or boofhead might even have one or know where one is . . you could pm them and ask.
PS - 276 ci is more than half way to a 289.
CONNECTING RODS
Buy used 302 rods . . should find some for maybe $70.00, or better yet, buy the ones below
$220.00 usd
http://www.summitracing.com/parts/sca-25090p/overview/make/fordPISTONS
Ford 3.8 thunderbird supercoupe pistons [or 260 stroker pistons]1.615 compression height 13 cc .912 pin . . these will be at exactly 0 deck height on a stock block . . $400.00 usd
http://www.summitracing.com/parts/wis-pt113a2/overview/ROCKER STUDS
Put pins in them . . if you don’t your studs will pull up . . the pin kit is only $10.00 and fairly easy to install.
VALVES
Buy stock non rail rocker type 289 valves . . they will be more than big enough for your app and will not cost much extra in labor to install and your old valves may be worn out anyway so its almost a free upgrade
260 valves . . . in 1.59 . ex 1.39
289 valves . . . in 1.67 . ex 1.45
EXHAUST MANIFOLDS
260 thru 302 are all the same size so your stockers will be “ok”.
CYLINDER HEADS
have them milled to 49 cc's . . this will give you 9.0 compression with all the parts i mentioned . . you currently have around 8.6.
have them do a 3 angle cut on the seats and "back cut" the intake valve . . this will increase power and shouldn't cost much more than a standard valve job.
CAMSHAFT
$117.00
http://www.summitracing.com/parts/cca-31-230-3/overview/make/fordVALVE SPRINGS
buy comp cam springs to match the cam . . the ones below are for that cam . . $61.00
http://www.summitracing.com/parts/cca-942-16SPRING RETAINERS
$54.00
http://www.summitracing.com/parts/cca-768-16VALVE LOCKS
$18.00
http://www.summitracing.com/parts/cca-601-16LIFTERS
Comp lifters SUCK . . I use cranes $93.00
http://www.summitracing.com/parts/crn-99280-16/overview/make/fordROCKER ARMS
if your rocker arms are worn on the tip at all, you need new ones . . i would buy the comp roller tips below because they are EXACTLY the same price as a set of stock ford replacement rocker arms.
$160.00
http://www.summitracing.com/parts/cca-1442-16/overview/make/fordDISTRIBUTOR AND IGNITION TIMING
1. buy the springs below and replace only the heavy stock ford spring with one of these . . leave the lighter stock spring in place.
$6.00
http://www.summitracing.com/parts/mrg-925d/overview/make/ford2. unplug the distributor vacuum advance hose.
3. set the initial timing at 10 degrees btdc.
4. reconnect the hose to ported vacuum on the lower right side of carb.
CARBURETOR
Your stocker is a bit small . . you can buy a used orig 2 barrel cheap and use that . . your carb should have 1.01 on the side as shown below . . you want one that says 1.08 or 1.14
start with #52 main jets on any ford carb you use.
