.....the new flasher module
andrew, what type of flasher module did you use,an electronic or standard?
Can you go a bit more into how these are installed? I see you include load resistors, presuming these are to restrict the power going to the bulb? Do these sorts of things have any impact on the fuse box and so forth?
speed, your fuse box etc will not be affected.
if using these led's for front ind/park and keeping normal (incandescent) bulbs in rear, like i have, you only need an electronic flasher unit for both front & rear indicators to flash in sync and regularly. The load resistors arent necessary for this setup. When using the sequential setup i havent got my head around that yet.
i'll let shaunp or boof tackle that one, its still sunday and ill need some of my brain for monday morn....
