Hi everyone,
Looking for some help sorting out a vibration in my 66 coupe. It was there when I bought a car a little while ago but I wasn't too fussed as I bought the car for the excellent body and numerous new parts and plan some major driveline changes anyway. Those changes now have to wait a year or so due to some other developments so I've been trying to sort out this vibration.
The car has the original or replacement 289 that apart from a Pertronix and dual exhaust (after the standard manifolds) it's standard 66 C code. C4 behind it. It does have after market aircon fitted.
The vibration is not what I'd call severe and only appears from about 1,000 revs to maybe 1,700 or so. It's not there at idle, which is nice and smooth and disappears once it has a little bit of speed up. While the engine's a bit tired, at idle and above about 1,700 it runs smoothly and pulls as strongly as such a basic little motor should. Things I think can be ruled out are:
- uni joints and tailshaft as the vibe is there when the car is stationery and in park
- engine and trans mounts which are new and torqued correctly
- a misfire situation as there is no stumble during this vibration phase of the rev range
- aircon compressor, I wondered if the pulley was out of alignment even though it looked OK but removing the belt didn't change anything.
Yesterday I pulled the inspection plate off the front of the bellhousing to check the convertor bolts. These turned out to be nice and tight. However, I discovered the nice shiny new flexplate has a dirty big weight welded to it and seems to be a 50 oz job rather than the 28 oz one that should be there. I haven't been able to figure out how to insert pictures here but it looks the same as images of 50 oz plates I googled, and way different to an old 28 oz one I have lying around.
If the harmonic balancer isn't also 50 oz maybe this is the answer. However, I can't see how such a mismatch would lead to a vibration only in a pretty narrow rev range. I would have thought this would cause a problem right across the rev range, get worse as revs rise and be way more severe than my problem. Is this right?
If such a mismatch is the problem, is it possible to determine the imbalance of the harmonic balancer visually? If so, what am I looking for?
I'm thinking that replacing the balancer would be easier than replacing the flexplate. I've done the latter before and it's a pain and I'm pretty sure on this car I would have to cut the exhaust system.
Finally, while I know that describing it as not too severe isn't real precise, what might be the implications of just continuing to drive it for another year or so? - no more than 90 days and only a few thousand k's in total at most.
Grateful for any advice and suggestions. Thanks in anticipation.
