Ford racing only do a 363 now, but must use a new block ,347 new block or near new and sonic tested for sure ,old ford block std bore try boring that out ,they are pretty thin may be ok ,but not for a stroker .347 stroker are ok but a 331 is safer. I would go later block ,hyd roller cam etc ,just like mine now mild but good power ,very good on fuel starts 1st time every time and goes fairly good ,3.25 ratio.26 inch tall tyres ,so good on hwy,makes it a bit slow off the line for drag racing but is my cruise car and still runs 12.5 at 114 mph . with a 670 vac holley. Bigger carby,lower diff gears ,bigger hi stall would run 11.9, i would think . My stang is a total sleeper std inside and out just a little lop out the back . Running a 351w the only thing you have to change is the extractors ,depending on your water pump ,for radiator side left or right .
