glen sorry this is not directed at you, its a general thing, directed more at the sheep mentality a lot of aussies have
remember this, most big teams in racing use aussies, as our tech is way up there!
to continue:
you know it still beats me, why people recommend fitting a slipping clutch (hi stalls) to cars?
are you not better off getting, a well designed cam that allows good idle, yet still enough lift and duration for big top end power?
we are in a technical age, where this has been possible for the last 15-20 years
have a look a the lsx engine, its still a push rod engine, just good cam design factory (poor from some well known cam co's)
i have one making over 700hp idles at 950-1050 has a nice lope @ idle and drives like a corolla with the torque of a mack truck!
granted efi has a great part in this being possible!
some stall converters are well made and can cost over $1k. they can also use external pumps to give variable stalls
(i admit even though being involved in trans builds since 1985 ive not kept up with converter design)
most are not, as such most just slip heating the fluid up, thus shortening trans life, wasting torque and fuel at the same time.
this is overcome in late model converters with lock ups installed (and then our brainless converter shops remove them in the name of performance)
it is true manufacturers engineers don't always get it right but more often than not they do! this is where we aftermarket shops with back yard budgets need to think hard to stay ahead!
as discussed with Pash
1 get the best flowing heads you can afford
2 get a roller cam gave him an idea of specs
3 get pedestal rockers that do not require guide plates
4 get the best tubes and intake you can afford for carby or efi
5 get your block checked (sonic, crack etc.)
6 go 347 as this is best value and the money saved is best spent above
7 get a c10 as its at least 40% stronger than a c4
8 build the c10 with extra h/d clutches and bands
fit it and enjoy it, as it will be above 500hp eyes closed done right
edit: just a video of whats possible with some thought process
http://www.youtube.com/watch?v=tMFedWxvn3c
