Hi Dale, Yes - Ron is booked in at 8AM tomorrow morning. Can see no reason why it will not pass this time. Engine is running smooth as silk, crossmember looks like new, wheel alignment and report all done, indicator switch working as it should. Heck - even the back seat is locked in
Was waiting for Jeremy to go to Dave`s to pick up the Red Mach1 this arvo, but no need. Brad drove it back!:yellowpepper: -
Engine is running sweet -
Lot of jobs left to do, but not much time left. Alternator light is on all the time, so the Auto Electrician is calling in tomorrow morning to sort that. Then Jeremy can put the rest of the dash together, followed by door trims, followed by seat belts, followed by.......etc
Luke will be busy doing the scuff and buff, while Brad sorts out a few mechanical bits left to do.
Wheel alignment Friday, then Stripe man late Friday.
Think it will be a stressful couple of days!
The Grande arrived back from the Auto Electrician -
Here is the Sanden Conversion -
Jeremy fitted a new radiator this arvo. We realized upon removing the old radiator that it was only a 2 row core - New radiator has 3 rows of tubes - much better!
Also fitted a new heater outlet to the inlet manifold. Think that should cure the leaking coolant problem.
Just have to refit the centre console and give the car a good clean. decided to fit the Leather Steering wheel for the trip -
Rocket.
