Author Topic: Do you have to degree a new cam ?  (Read 487802 times)
« Reply #1175 on: April 15, 2016, 11:10:32 am »
I have never seen a fan with that steep of a pitch either . Must be some top secret race stuff and is made from prefabulated amulite or something . Or perhaps the builder used that type so the blades wouldn't go thru the bonnet when they fly off.
 :lmao:
Also notice the "auxiliary" fan belt sheaves . If the other one wears out in the middle of a race, you can just move the belt forward.  :thumb:
I'm pretty sure his industrial strength alternator bracket won't break though.
Anything else ??  :lmao:
« Reply #1176 on: April 15, 2016, 11:11:50 am »
Hardy ha friggin ha  :lmao:  :cry:
It was so good to hear it run, and actually run and not grenade itself...
So i did all the hard stuff right it seems but now something as simple as a leak...
FFS  :ouch: :ouch: :ouch: :ouch:
 :thud:
Well look on the bright side, the inside of your engine has now been "washed" so it's very clean.  :lmao:
« Reply #1177 on: April 15, 2016, 11:13:21 am »
Don't forget the $160 in oil..  :thud:
« Reply #1178 on: April 15, 2016, 11:13:33 am »
Yes, but I thought that was enough for now.  :lmao:
« Reply #1179 on: April 15, 2016, 11:15:07 am »
Oh no prob . Just put it in one of the misses big pans then put it on the stove and heat it to 215 f and all the water will simply evaporate right out of it.  :thumb:
« Reply #1180 on: April 15, 2016, 11:15:51 am »
Alright, well.
Time to go pull the fkn intake back off...
Here i was thinking. Get the timing etc sorted today, dash etc back together and maybe take it for a run next day or so.
And the gods just gave me the fk YOU !!  :cry: :lmao: :lmao:
« Reply #1181 on: April 15, 2016, 11:17:09 am »
Alright, well.
Check a couple bolts first just so you know if they were loose or not.
Hey, this will also give you the bonus of being able to check the pattern on your fancy new dist gear.  :lmao:
MARK WHERE THE ROTOR IS ON THE DISTRIBUTOR SO YOU WONT NEED TO SPEND ANOTHER 4 HOURS TRYING TO GET IT TO RUN.
« Last Edit: April 15, 2016, 11:20:18 am by barnett468 »
« Reply #1182 on: April 15, 2016, 11:20:52 am »
When facing the engine.
The leak is coming from the back left, and from what i can see its right in the corner where the head, block and intake meet each other.
From what i can tell anyway.
« Reply #1183 on: April 15, 2016, 11:21:39 am »
You taking the piss right ?
No, I already urinated earlier today.
« Reply #1184 on: April 15, 2016, 11:26:47 am »
Your not serious about cooking the oil
« Reply #1185 on: April 15, 2016, 11:33:31 am »
Page 48  :cool:
« Reply #1186 on: April 15, 2016, 11:36:40 am »
What,  does it have water in the oil ? By the way Fitzy you have done an amazing job  :thumb: .
« Reply #1187 on: April 15, 2016, 11:40:17 am »
Even if he is there will be consequences doing what he said that will make the dramas you have faced until now pale into insignificance.
As Glenn said, amazing job. I'm in awe of you taking this on and have learnt a lot, mostly that I'm staying on outside of my engine.
« Reply #1188 on: April 15, 2016, 11:40:24 am »
Cheers mate,
Yeah, im hoping its the intake.
There is a small leak from the rear left, maybe i didn't seal around the port well enough. I hope that's it and not the timing cover
« Reply #1189 on: April 15, 2016, 11:43:02 am »
The bolt second from the rear on the left side was i guess loose.
When i say loose it was tight but i could still tighten it maybe a few mm or so.
« Reply #1190 on: April 15, 2016, 11:52:31 am »
Thanks buddy.
Consequences ? As in my wife walking in to a big pot of engine oil cooking away on the stove..  :lmao: :lmao:
« Reply #1191 on: April 15, 2016, 12:14:35 pm »
...in HER cooking pot....Just trying to help.  :lmao:
« Last Edit: April 15, 2016, 12:18:30 pm by barnett468 »
« Reply #1192 on: April 15, 2016, 12:16:43 pm »
ok, then you definitely did NOT follow my instructions exactly, which is obviously kind of a bad thing.
Hopefully there will be something obvious to see.
« Reply #1193 on: April 15, 2016, 12:18:16 pm »
Yep, that's what I meant.
Great day here in Melbourne so I'm taking my Mustang and my beloved for a drive up into the hills for a coffee or something. Did you know that you can do that with these cars? Drive them?
« Reply #1194 on: April 15, 2016, 12:19:59 pm »
Couldn't help myself.
Cruel!  :lmao:
« Reply #1195 on: April 15, 2016, 12:22:52 pm »
Hey Fitzy, maybe you should stat a new thread titled "How do you PROPERLY intstall an intake manifold?".  :bolt:
« Reply #1196 on: April 15, 2016, 01:05:28 pm »
Hope it breaks down Geoff  :toetapping: :lmao:
I just like using mine as a very expensive driveway ornament..  :cry:
« Reply #1197 on: April 15, 2016, 01:10:45 pm »
Alright,
Intake off it is...
Enjoy the drive Geoff....  :thumbdown:  :lol:
« Reply #1198 on: April 15, 2016, 01:24:21 pm »
« Last Edit: April 15, 2016, 01:25:58 pm by Fitzy1980 »
« Reply #1199 on: April 15, 2016, 01:45:45 pm »
So it got water into the sump/ pan  :thud:   So fresh oil and filter needed .
