XLNT
POST A PHOTO OF YOUR CAM CARDS . THEY SHOULD HAVE GIVEN YOU ONE WITH THE $18,000.000 ENGINE . IF YOU DONT HAVE THAT ONE I WILL CALL SNAUSAGE MONDAY.
the top photo goes to the rocker but it looks like they may have had them in upside down
the idiots must have put a reduced base circle cam in it.
these are common base circle sizes, however, these sizes can vary depending on lobe lift.
std base circle ........... 1.340
reduced base circle .... 1.260
difference .................. .080
I will call the cam mfgs Monday, and if i can get the base circle numbers, you should be just fine if you get push rods that are shorter by the amount of difference there is in base circles between the two cams and then the potential tragedy will be averted . You can Ebay yours to get some money back.
The closest ones are 6.875 which is fine . I would get the ball end type like you have if possible.
Here's standard end rods . You need .080 wall.
http://www.summitracing.com/search/part-type/pushrods-assembled/intake-overall-length-in/6-875-in/wall-thickness-in/0-080-in?N=4294894148%2B4294876053%2B4294887316&PageSize=100&SortBy=BestKeywordMatch&SortOrder=Ascending
