Tunnel rams will give you more power at 7000 - 9000 rpm.... if your heads/valves and cam can flow the air, and the crank and rods could stay connected.
They also take away from the bottom end power.
A nice dual plane, or if you want to move the power up higher, and make more power, a single plane manifold will be nice. A manifold pattern (dual plane, single plane or tunnel ram) and the height & length of runners, and the diameter of the ports, are balanced by the operating RPM, Cubic capacity and carb/valve sizes and cam profile.
You can't "Test" compression, to see what ratio it is, you need to measure it.
If it were me (I have a good understanding of engines, and can be happy when it blows up) I would consider chucking the blower on, and tuning it, and seeing how much boost and timing I could throw into it, and see what I end up with.
Not a recommended course of action, if you would be shattered if it died though.....
I have a friend with an XF falcon turbo. He has an ongoing order with the local wreckers, for good running AU 6 cylinder motors. He has a swapover down to less than 1 hour, from drive in to checking timing.... He calls them (engines) tin soldiers, he has a platoon of them sitting in his garage, awaiting their tour of duty.
