Originally posted by ozbilt
Originally posted by mikes68
I'm inclined to over-engineer these things a bit sometimes.
A bit !!!! :w
Sorry, that was uncalled for....
:w :w :w
Issue you will have is the braces getting in the way, particularly if working on the rear tail light panel. Those ones of mine (built 6 of them) are still going no worries & the only brace on mine is the gusset on the bottom. You can see I transported stuff every where loaded on my trailer.
I'm only planning on gussets (that was the word I was looking for - not braces) for the top and bottom as well and the bottom one is not going to extend any further than the end of the pipe at the top so I shouldn't have any dramas with the tail light panel fouling (fingers crossed).
Each end is holding up about 200kg (300kg on a big car), so not much when you consider the strength of RHS .
;x - Seriously, is that all?!?!? I have always been wondering what the bare shell weighs. I only guesstimated by subtracting the weight of the diff, engine, trans suspension etc. I thought the whole car weighed around 1,500 kg and figured minus all the other stuff it might be around 800kg.
Glad you are having fun drilling spot welds, the misshapen ones are because the weld is produced by a copper tip & with extended use they become soft & go out of shape.
YEAH... that is SOOOO much fun:+
BTW, your welding is excellent, you will have no issue getting the strength needed when welding the panels back on the car. Are you left handed?
Cheers, had a bit of practice in my time and doesn't usually take long to get back into the swing of things and besides, when set right, mig welders are a breeze to use.
Oh, and I'm definately right handed but have had plenty of practice welding south paw that I would almost consider myself ambidextrous when welding - not quite but almost.
