I have finished removing all the bits and pieces from the dash now. The wiring was a little bit of a pain in the a#se to "unthread" and pull through the firewall although there was probably really no need as I should have just cut it either side of the firewall as it would have been so much quicker. The harness has aged too much to bother about reusing with many cracks and splits in the deteriorated insulation that it would just be a fire hazard waiting to go off...
[IMG=512x384]http://i807.photobucket.com/albums/yy353/pyer8s/Intoweek3-day2005.jpg[/IMG]
Removing the light switch ("ahhh yes" I hear the experienced ones say) was a little challenging... until I remembered Alex's blog (
http://68vert.blogspot.com/search?q=light+switch) which shows it very clearly. I borrowed the next 2 pics from his site and added the textual explanations.
[IMG=700x525]http://i807.photobucket.com/albums/yy353/pyer8s/Lightswitch-1.jpg[/IMG]
[IMG=700x525]http://i807.photobucket.com/albums/yy353/pyer8s/Lightswitch-2.jpg[/IMG]
So this is what the "project" looks like now...
[IMG=512x384]http://i807.photobucket.com/albums/yy353/pyer8s/Intoweek3-day2009.jpg[/IMG]
I'm just waiting on the arrival of the steel to make the full body jig and I will rip into the floor pan and rockers.
I'm also trying to find a decent quality and sized spot weld removal tool here locally so I can get into the front seat riser and upper / lower cowel removal. If anyone knows where in Perth they are available then sing out...
