Removing antenna off a 69
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Technical & General Discussion Area
Tech Torque Pre 1973
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Removing antenna off a 69 (Read 1444 times)
mjb0015
Worked
mjb0015
on:
February 05, 2010, 10:23:44 am »
Hi everyone, I am having trouble removing my antenna off my 69, is there any trick to this, do I need to remove the inner guard?
mjb
Logged
tim_morrison82
Blue Printed
tim_morrison82
Reply #1 on:
February 05, 2010, 12:16:01 pm »
i am pretty sure there is either a clip or a nut holding the antenna in place. which is only accessable behind the panel.
well at least thats what i found with my 68.
Logged
tim_morrison82
Blue Printed
tim_morrison82
Reply #2 on:
February 05, 2010, 12:17:30 pm »
there maybe an easier way in there...?
Logged
soc123_au
Blue Printed
soc123_au
Reply #3 on:
February 05, 2010, 12:52:48 pm »
It depends on the Antena & where its located on the guard. You will most likely need to remove the splashtray & then you should be able to access the nut. They are often siezed so give it a hit with inox or wd40. Also the inner shaft can spin with the nut, if that happens its time to break out the grinder.
Logged
mjb0015
Worked
mjb0015
Reply #4 on:
February 05, 2010, 02:51:14 pm »
Thanks everyone, I will let you know how I went
mjb
Logged
non member
Top Streeter
Account Closed
non member
Reply #5 on:
February 05, 2010, 06:49:56 pm »
Rectangular base antenna would be on them standard. The base (stainless steel) unclips & you can slide it up the mast. Then you will see 4 phillips headed screws holding the base down.
Logged
Print
Pages: [
1
Go Up
« previous
next »
