Hi,
I too have one of the 21 circuit EZ Wire harnesses. It is good quality at a fair price. I spend a good day laying mine out and sorting the runs and making it neat. I have been pretty fussy but planning will pay off in the long run with any wiring. I had the luxury of printing out the entire wiring diagram. It is about 1.5m square.
The wires are long enough that you can route them under the guards so that they are hidden in the engine bay. Any circuits that I am not using (only 2 or 3) I am going to pigtail with a bullet connector. Be aware that the fuse block is about twice the size of the original one. I am mounting mine under the LH dash against the side panel, It is a tight fit but fuses wont be too hard to replace. The block does not come with mounting plate so I made one out of a bit of scrap alloy.
I will add a couple more photos once I find them.
Ash
