I finally had the time to take the trim off completely, and found a number of small clips along the bottom windshield trim, but they are not secured to studs; they are merely pressed firmly into the mastic under the windshield rubber (sorry, no pics, I was doing it in the rain yesterday). The pillar trim pieces are secured by two screws on the inside of the door frame, and brought reasonably close but not tight to the windshield rubber by one v-shaped metal bracket on each side. All in all, a rubbish fit. Not to mention, it seems that under the bottom trim, I have revealed that the cowling is separating in an almost perfect line about 1cm from the windshield. Not sure what that is all about.
So, new clips, old clips, leave it alone before it all falls apart,...?
And in a desperate plea for help, can someone please tell me how to get my wipers off when pushing anything inside that supposed release hole does not work? I have tried so many times with way more pressure than I am happy using that close to a painted surface.
Thanks.
Jeremy.
