Lowering Upper Control arms - the 'Shelby Mod'
Author Topic: Lowering Upper Control arms - the 'Shelby Mod'  (Read 8084 times)
« on: August 11, 2009, 12:56:39 pm »
Offline moe
  • Name: "Moe"
« Reply #1 on: August 11, 2009, 01:05:19 pm »
Offline non member
  • Account Closed
« Reply #2 on: August 11, 2009, 01:05:31 pm »
Scan it & save as a .jpg that works for me.
« Reply #3 on: August 11, 2009, 01:07:40 pm »
I ended up cutting & pasting into Powerpoint - you can then save it all as a picture file - then loaded it onto a website and put the links into the page!
Took a while, but there it is...
Offline non member
  • Account Closed
« Reply #4 on: August 11, 2009, 01:09:10 pm »
Well done, now I know that as well! Thanks
Offline Frank70
« Reply #5 on: August 12, 2009, 09:37:39 am »
This might be a dumb question - is this mod still useful on a car with a coilover front end (ie. RRS ) ?
I have the stage one kit that retains the stock upper and lower control arms.
Frank.
Offline non member
  • Account Closed
« Reply #6 on: August 12, 2009, 10:40:11 am »
Frank.
The RRS coilover front end is a strut, so does not have an upper A arm. Not a particulary good "handling" mod as there is no camber gain.
The TCP coilover however does benifit from the "drop" & the top A arm they produce has the "drop" built in, if you wish. Also has the taper built in on the ball joint so it does not bind.
Offline Frank70
« Reply #7 on: August 12, 2009, 12:05:52 pm »
Thanks Kerry.
You know I never realised that the upper A arm was gone !
Frank.
Offline nassi
« Reply #8 on: August 12, 2009, 10:01:50 pm »
Thanks Kerry.
Frank.
Didnt you miss the squeak? :+
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline Frank70
« Reply #9 on: August 13, 2009, 07:07:31 am »
hehe
Offline 69candy
« Reply #10 on: August 13, 2009, 08:41:17 pm »
hehe
Jeez. I know your sig says you live here but 4.37AM;x
« Reply #11 on: August 14, 2009, 01:23:54 pm »
Frank.
so Frank - do you still use the stock upper & lower control arms - or is the top one gone as per your next post? If you still have the stock upper, then the mod is an option for you, if you have an aftermarket one, or don't have one at all, then you should be fine at the geometry is likely to have changed anyway...
