Bent plates ( front ) are illegal in Victoria, so I just got some solid rubber dowel, drilled it and with longer screws attached plate flat, to the front with no probs.
It sits about 20-25mm out from normal position but looks quite neat.:(
These are personalised, standard, 6 digit Vic plates.
Rear plate fitted flat in normal position without any special stuff required.
