I've only ever done the XB swap, which requires cuting the push rod shorter to the pedal, but they do fit the pedal, some holes in the fire wall and some new brake lines. The Gem would be similar but you will also b\need to get the master cylinder push rod right. You may have to fabricate a push rod from your old one and the Gem one.
