Fuel
Author Topic: Fuel  (Read 5257 times)
Offline brentley
Fuel
« on: June 16, 2005, 04:47:02 pm »
Being a newbie Iam not sure what type (grade) of petrol to use in a C code 289 I has had a little work done on it with an edelbrock performer intake manifold and holley 650 carb added.  I hear west australian fuel is of pretty low quality and so I want to get the best out of my car.
Offline nassi
Fuel
« Reply #1 on: June 16, 2005, 05:34:15 pm »
Hi Brentley, I use BP ultimate as this is 98 octane, best available. If you havnt modified your heads for unleaded fuel you would be wise to use an additive.
nassi
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline 2233
Fuel
« Reply #2 on: June 16, 2005, 06:24:05 pm »
What is the compression ratio of your engine?
Offline ThunderKiss
Fuel
« Reply #3 on: June 16, 2005, 10:59:44 pm »
I used to use Shell Craptimax but the car ran poorly when cold:(.  Now I use Mobil Synergy 8000, it's much better.  I haven't tried the BP one yet.
Offline Pete
Fuel
« Reply #4 on: June 17, 2005, 10:00:50 pm »
B.P. Ultimate, Mobil 8000 and the new Caltex 98 octane Vortex are the same product and are loaded from the same facility. At least here in Victoria anyway. Shell Optimax is a similar product, coming from Shell's Geelong facility.  Both of these 98 Octane fuels are very much the same in every way, which makes me ask the question, why do you think one is crap and the other not???
Offline ThunderKiss
Fuel
« Reply #5 on: June 17, 2005, 11:14:39 pm »
Pete, my car just seems to run better on Mobil 8000 when cold.  With Optimax it feels as though it's running rough although when warmed up and cruising steadily I can't feel a difference.
The other thing is I live at the top of a steep hill and with Optimax at full throttle going up the hill the car pings a little while it doesn't with Mobil 8000.
Offline Pete
Fuel
« Reply #6 on: June 19, 2005, 07:09:54 pm »
At the end of the day it could be many things that make a small difference with fuel. I guess when you're on a good thing stick to it. Cheers Pete
