Originally posted by whiplash
Originally posted by mistermustang
would you get them to build you a stroker?
The Names on my hood !!!! HIFLOW ENGINES all the way :(
Woody does world class work . He's the only bloke apart from my dad that I'd trust to build my engines ( He's building my new drag combo )
heard from the boys at Odin Auto Parts (peter and company) that woody's pretty good. also heard from them that he learned his trade from 'Uncle Con the Engine Builder' also in Balcatta. i'll be talking to both of them.
i have decided to import the major parts myself, and have an experienced shop do any balanging/machining/assembly/break-in and dyno-runs. Parts i'm importing will include CS Alum block and CS Alum heads, Scat stroker crank rotating assy, Harland Sharp roller rockers, Edelbrock windsor dual-quad intake with 2x450cfm Holleys, Cloyes timing gear and Shelby alum oil-pan and valve covers.
part of my dilemma is warranty. if i supply the parts i save approx 50% on the cost of the engine, but only labour is warranted by the builder. if they supply the parts then the cost goes way up but everything is warranted.
:_
