I have a problem with my dash guages in my 66.
The speedo is incredibly inaccurate, and sometimes the needle goes all the way to the 6 o'clock postition when stationary, and starts from there, so you are doing around 40mph berfore it hits zero. it also used to make a ticking noise.
the fuel guage also was inaccurate, and read 1/2 full when full. then it stopped working altogether. i earthed out the sender wire, and nothing changed, so i assume the sender is ok.
the other guages do not work, i believe the previous owner disconnected them, and installed Autometer's. although, i would have expected the amp meter to still work.
any help or tips appreciated, thanks
