I like that.......Hey ech .........I CAN SAVE YOU MOney.....you can go to the wreckers and get the relays off an XF and they are on individual sub bases they are on the R/H front inner guard, and can latch onto each other.
The late model stuff like EL and up have a 4 bank relay base on the L/H side just behind the headlice, but they aint detachable....
Then all you have to do is run a wire from the relay main supply to the battery and put a 100 amp fuse in it then wire your existin lights to it.....easy A?.....Then go down the Bottlo and spend what you saved on a carton and relax.
