Had overheating probs in traffic on a hot day (when stuck at lights etc) My 289 is newly recon at .030" oversize. I have a high flow thermostat, modified water pump with high flow impellor, a new 3 row radiator (not a genuine one, a fabricated one with a natrad dimpled core) that still uses the original radiators side brackets. A repro fan cowl and mounting brackets that made the cowl sit about 1/2 inch from the core. I have a 6 blade fan, original type. My car has air con, I believe it should have a 5 blade fan, but should not see any problems with my 6 blade. My fan cowl brackets I have had for a few years now, and have just discovered there are two different size brackets, one to suit a 2 row rad and one to suit a three row rad. As my radiator is a three row, utilising two row radiator side brackets, I have the wrong fan cowl brackets, making the cowl sit to far away from the radiator. So, I bought the shorter fan cowl mount brackets as well as the aftermarket fibre plastic cowl and fitted them.
Did have trouble with the fan to cowl clearance (at the bottom) so had to slot the mount brackets to lower the cowl about 5mm and no more probs. The fan/cowl combination definately moves more air through the radiator at low revs, and I have noticed a substantial difference at idle in traffic, though, there is still room for improvement. Thinking about a more efficient fan that will still fit within the confines of my cowl. Any ideas anyone?
My radiator guy swears by a viscous fan clutch and a commodore fan, but problem is, won't fit with either of my two cowls plus the blades foul the top radiator hose. Interested in hearing other fan ideas
Scott:-
