Suspension options 1970 coupe
Author Topic: Suspension options 1970 coupe  (Read 751 times)
Offline Gez08
  • Name: Joe
  • Car: 1970 Mustang Coupe
« on: April 17, 2024, 10:15:06 am »
Hi everyone new club member here. I have just bought a 1970 coupe i would like to get lowered a bit but need to buy a kit for the leaf springs in the rear. any suggestions what to get or where to take it. I'm Geelong based but don't mind going to Melbourne if i need to.
Offline scollist
  • 65FB, 2017 GT
  • Name: Shane
Re: Suspension options 1970 coupe
« Reply #1 on: April 17, 2024, 02:12:28 pm »
General advice is to avoid lowering blocks.
Options are to either buy mid-eye or reverse-eye springs that will achieve lowering (but not an exact science as your existing springs may be sagged), or get a specialist to reset your existing springs (and maybe add a half or full leaf depending on their advice).
I did the latter on my 65FB about 10 years and got it done at Suspension City (used to be in North Melbourne but now in Pascoe Vale) - https://www.suspensioncity.com.au/.  Cost me about $440 back then, so would maybe be double now.
The benefit of the latter approach is they will get it sitting exactly how you want it, but with new springs its a bit of pot luck.
Shane
« Last Edit: April 17, 2024, 02:14:04 pm by scollist »
Offline RocketScientist
« Reply #2 on: April 17, 2024, 05:18:16 pm »
I got a set of 1 inch lowered springs from the USA and it was fraught with problems: slow, expensive and US Customs even bent one - which took more expense and effort to get straightened.
So, I think a good and cheaper option is to find a suspension shop specialising in leaf springs and have a set made to your requirements - and you'll be able to keep the lower spring with all the part numbers (which keeps it original). It is rare to find off-the shelf springs that will match your exact height requirements so having a custom set is a good way to go.
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
