/68 Beltline weatherstripping
Author Topic: /68 Beltline weatherstripping  (Read 1179 times)
Offline Darren Bullitt
  • Name: Darren
  • Car: 68 Fastback
« on: November 26, 2023, 12:10:36 pm »
Hi Everyone, wondering if anyone has a recommendation for a quality brand of beltline weather stripping to suit 67/68 Mustang.
I purchased a Fairchild KF2099 set but have found the clips will not hold tightly.
The clips push into the hole but will roll out when a little pressure is applied.
The kit consists of four pieces (L&R Rubber + L&R Felt)
The quality of the kit seems good just the clips are not holding tightly.
I ensured all holes were punched flat and the surface was prepared properly.
OR
Maybe I am doing something wrong???
Any feedback would be appreciated.
Offline RocketScientist
Re: /68 Beltline weatherstripping
« Reply #1 on: November 28, 2023, 07:32:22 pm »
I bought a set of Repops for my 70 and I was warned that these don't have strong enough clips, so it could be a common thing. I could think of no other way of securing them, so I glued them with a very good epoxy to make sure there was no way they would move and scratch the new glass.
« Reply #2 on: November 28, 2023, 07:34:26 pm »
Hey Darren,
My drivers side is much the same, I’d say after all these years the holes have worn a little.
Not sure if good quality 3M thin double sided tape is the answer.
Or, machined nylon spacers taking up the gap.
I’ll have a go and let you know!
« Reply #3 on: November 28, 2023, 08:00:08 pm »
Hey Darren,
Just to confirm we are talking about the outside rubber strip?
I had Quick look at mine and I think RocketScientist is on the money.
Carefully placed epoxy resin around the clips seems the best method of repair!
