Right angle Speedo cable for T5
Author Topic: Right angle Speedo cable for T5  (Read 2067 times)
Offline 1965 fastback
  • Name: Tony
  • Car: 65 Fastback
« on: July 04, 2023, 03:26:51 am »
I have an Australian T5 in my LHD 65 Mustang. The speedo outlet come out on the right side but has to cross the gearbox to get to the instrument cluster. I have just broken one after 500 miles of use because of the sharp turn of the cable coming out of the box.
Has anyone used a right angle connection in the cable to avoid the sharp turn coming out of the box?
If so, can someone recommend a product?
Re: Right angle Speedo cable for T5
« Reply #1 on: July 04, 2023, 08:50:40 am »
There are two cables available. The shorter one is for autos and connects to the trans on the (LHD) driver's side. The longer one if for a top loader and connects on the passenger side.
My American T5 has the connection on the driver's side and I used the same shorter cable that was on the C4 the car had when I got it.
Maybe you have the shorter cable and the longer one will solve your problem?
  • Name: Tony
  • Car: 65 Fastback
« Reply #2 on: July 04, 2023, 09:17:51 pm »
Thanks Geoff.
I actually got my speedo cable made up from a guy in Ringwood. I can get it any length. He said it wouldn’t last if there were too many tight turns (which turned out to be the case).
A right angle connector at the box I think is the only way to limit the tight curve. I’m just trying to work out where to get one.
I can always get a longer cable next time but the first right curve between gearbox and floor hump is the problem.
« Reply #3 on: July 05, 2023, 11:53:27 am »
Here you go: non reducing 90 degree converter.
https://www.ebay.com/itm/295557194590?
  • Name: Tony
  • Car: 65 Fastback
« Reply #4 on: July 05, 2023, 06:08:12 pm »
Thanks Jiffy!
