Best lube for window regulator
Author Topic: Best lube for window regulator  (Read 1445 times)
Offline torrus
« on: March 20, 2023, 06:52:41 pm »
I have removed the window regulator from my 66 and cleaned it up.  I think it has been replaced at some time as it is pretty good condition.  Going to clean it up, lube it up and put it back in.  Was going to use WD-40 White Lithium Grease but before I do wanted to ask has anyone had any experience with it or is there a better lube to use.
Offline USA066
  • Robbo
  • Name: Colin
Re: Best lube for window regulator
« Reply #1 on: March 20, 2023, 08:46:43 pm »
White lithium grease is the way to go. Also worth while checking your rollers in the scissors are in good condition while you are there, these are cheap to replace. Use white lithium grease on the runners also.
2007 GT Convertible
2008 Bullitt
1966 Coupe
Offline torrus
« Reply #2 on: March 22, 2023, 11:42:05 am »
Thanks.  Replacing the rollers is what prompted the post
