Headlights flashing
Author Topic: Headlights flashing  (Read 2758 times)
Offline Mylittlepony1966
  • Name: Kevin
  • Car: 66 coupe
Headlights flashing
« on: December 24, 2022, 10:17:43 pm »
1966, headlights are flashing. Mostly high beam. Regulator stuffed? Or maintainace required on it?
Merry Christmas to all.
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
Re: Headlights flashing
« Reply #1 on: December 24, 2022, 10:51:33 pm »
Fit a new headlamp switch and fit relays as well.
There is a circuit breaker built in to the switch, that's your problem especially if you have upgraded the lights.
  • Name: Kevin
  • Car: 66 coupe
« Reply #2 on: December 25, 2022, 07:31:23 am »
Thanks Peter, appreciate  the feedback. No issues fitting a new switch; however, I have a question in regard to the circut breaker you mentioned. Wouldn't the lights stay off if it throws the breaker? Standard headlights......
Thank you kindly. Have a great day
« Last Edit: December 25, 2022, 07:35:17 am by Mylittlepony1966 »
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
« Reply #3 on: December 25, 2022, 10:33:28 am »
There’s a kit from Custom Mustangs that has all that’s needed.
https://www.custommustangs.com.au/headlight-relay-harness-dual-40a-relays-30a-fuse-2
Or here’s the info to do it yourself.
http://midlife66.com/wiring/halrelays.html
The circuit breaker in the factory switch automatically resets.
https://www.motortrend.com/how-to/mump-1006-ford-mustang-troubleshooting-headlight-switches/
« Last Edit: December 25, 2022, 10:35:46 am by Clubman7 »
  • Name: Kevin
  • Car: 66 coupe
« Reply #4 on: December 25, 2022, 10:14:48 pm »
Thanks Clubman
« Reply #5 on: December 26, 2022, 08:08:40 am »
Hey LittlePony,
I fitted this one, very good, easy to fit and cheap.
Deletes some of your existing old headlight wires.
https://www.ebay.com.au/itm/165794744626
Another one a New Era relay, you wire it into your engine bay, you cut it into the existing wires.
https://www.ebay.com.au/itm/160993200038
If I was to do it again I’d take the time to fit the New Era relay.
« Last Edit: December 26, 2022, 08:10:22 am by AussiePhil »
  • Name: Kevin
  • Car: 66 coupe
« Reply #6 on: December 26, 2022, 08:45:41 am »
Thank you all. After a point in the right direction & further research, I have ordered a new dimmer(was playing up anyway), new headlight switch and a relay wiring loom bypass.
Still standard headlights at the moment. Any suggestions  for upgraded headlights?
« Reply #7 on: December 26, 2022, 09:26:28 am »
Definitely Hella C4 halogen conversion.
Offline Clubman7
  • Cruising.
  • Name: Brett
« Reply #8 on: December 26, 2022, 12:28:25 pm »
Was lucky with my 66 that someone had done the relay wiring and the H4 globe conversion headlamps.
  • Name: Kevin
  • Car: 66 coupe
« Reply #9 on: December 28, 2022, 12:08:44 pm »
Thank you Halogen seems to be the go.   :cheers:
