Top End Rebuild
Author Topic: Top End Rebuild  (Read 3078 times)
Offline Andrew_Coyote
  • Name: Andrew
  • Car: Mustang
Top End Rebuild
« on: December 01, 2022, 07:03:52 am »
Hi all
was wondering if anyone has done a top end rebuild if so what gaskets were used what brand and also if the head bolts were replaced please and thank you
Re: Top End Rebuild
« Reply #1 on: December 11, 2022, 12:35:22 am »
Beat any brand of gasket is fine. Fel pro is the most common brand in the us. . I have never replaced head bolts. The originals are usually fine to reuse. . Tap the exhaust bolt holes to insure the exhaust bolts go in easily.
Online GEOFF289
Re: Top End Rebuild
« Reply #2 on: December 11, 2022, 09:32:31 am »
If you're replacing the exhaust manifold gaskets Remflex are hard to go past. I put some on mine a few years ago on Barnett's advice. I just put some Felpro rocker cover gaskets on and they seem pretty good, certainly solved my oil leak problem I had there.
Re: Top End Rebuild
« Reply #3 on: December 11, 2022, 01:26:59 pm »
I always use fuel pro gaskets . Buy a full set and it has everything you need and cost only a bit more than just the top end kit  .  Top end gasket has limited gaskets .
Online Aussie-67
  • Name: Tony
  • Car: 67 Mustang Coupe
Re: Top End Rebuild
« Reply #4 on: December 11, 2022, 06:46:36 pm »
Felpro will do fine.  They have been  around since  Noah was a boy so they are a proven OEM.
