69 Instrument Cluster not working
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 69 Instrument Cluster not working (Read 3837 times)
demon69
Stallion
I'm new here
demon69
on:
May 03, 2022, 06:45:40 pm »
Hi
My instruments are operating intermittently, when I start driving they seem to be working okay but at times all the gauges go to zero, ie, oil pressure, temp, fuel.
Any ideas?
Peter
Logged
peter9231
Member-Society of Automotive Engineers Australasia
Worked
Car: 66 convertible
peter9231
Re: 69 Instrument Cluster not working
Reply #1 on:
May 03, 2022, 08:36:36 pm »
Voltage regulator on the back of the dash is "juicy fruited"
Logged
demon69
Stallion
I'm new here
demon69
Reply #2 on:
May 03, 2022, 11:05:58 pm »
Thanks Peter, what's your confidence factor that the reg is stuffed??
Logged
67FBGT
Blue Printed
Car: 1967
67FBGT
Reply #3 on:
May 04, 2022, 10:50:09 am »
Good idea to replace the 50+ yr old style regulator with a modern solid state one.
But thoroughly check the earth connections for the cluster seeing as the issue is intermittent. I'd do that first up.
Logged
jiffy
Supercharged
jiffy
Reply #4 on:
May 04, 2022, 02:34:37 pm »
Agreed - more likely to be an earthing issue rather than a regulator issue - easy way to check - at night when the lights are on, do the dash lights go out/back on at the same time?
Logged
Juanball mustang
Stallion
I'm new here
Juanball mustang
Reply #5 on:
May 04, 2022, 07:34:49 pm »
Alright , my guess is the printed circuit board .
Logged
peter9231
Worked
Car: 66 convertible
peter9231
Reply #6 on:
May 04, 2022, 08:52:52 pm »
Quote from: demon69 on May 03, 2022, 11:05:58 pm
100%
Logged
pmb0186
Thoroughbred
I'm new here
Car: 66 MUSTANG
pmb0186
Reply #7 on:
May 07, 2022, 11:04:51 pm »
agree voltage regulator or wire to or from.
the 5v produced from the reg powers the gauges and that all gauges are effect indicates common item.
Logged
does anyone remember laughter
Print
Pages: [
1
Go Up
« previous
next »
