clutch master cylinder
Author Topic: clutch master cylinder  (Read 3022 times)
Offline 65 Fastback
« on: January 31, 2022, 11:22:25 am »
Looking for advice on a clutch master and slave cylinder set up on my 65 which I am converting from the mechanical clutch it came with. I assume the master cylinder mounts in the same place where the clutch rod protruded through the firewall in it's original form? I have heard some have unique master cylinders that mount elsewhere to avoid the brake booster? I can't visualise how that works...
Also, does the slave cylinder mount to the side of the bellhousing? I'm using a top loader bell modified for a T5. I assume the clutch fork has to complement the bellhousing I am using rather than the gearbox?
Thanks for your help.
Tony
Re: clutch master cylinder
« Reply #1 on: February 01, 2022, 08:41:42 am »
I have a T5 in my '66. I have a clutch linkage and master from Modern Driveline https://www.moderndriveline.com/ that offsets the master hard up against the inner guard under the wiring connector, leaving room for the brake booster. Its a very clever bit of gear that multiplies the force you apply with your foot making for a nice light pedal, certainly compared to the old mechancial linkage. In my case I have an internal concentric slave/throw out bearing but the same master set up works with an external slave.
Your best bet though is to have a chat with Mal Wood. https://malwoodauto.com.au/ Mal can do you an under dash slave set up so only the hydraulic line is going through the firewall, using the original mechanical linkage hole. If i was doing it again this is the way I'd go.
« Last Edit: February 01, 2022, 09:20:17 am by GEOFF289 »
« Reply #2 on: February 04, 2022, 07:47:44 am »
Hey 65 Fastback.
Check out this link for clutch master and slave cylinders.
https://www.rosehillperformanceparts.com/Products_Page.htm
Offline efi Coupe
  • Name: Dave
Offline Tempest
« Reply #4 on: February 05, 2022, 06:16:06 pm »
I've got the Mal wood under dash clutch master kit in mine too and it's great.
That with a hydraulic throw-out bearing and the clutch in my mustang is nicer than the clutch in my daily drive  :thumb:
Offline 65 Fastback
« Reply #5 on: February 14, 2022, 03:50:30 pm »
Thanks all for your replies. So many options...
