Wanted: parts for v8 conversion - 65 Mustang
Author Topic: Wanted: parts for v8 conversion - 65 Mustang  (Read 6510 times)
Offline 65 Fastback
« on: January 05, 2022, 04:08:45 pm »
I am chasing a range of parts to complete what I need for a v8 conversion in my 65 Mustang.
Let me know if you have any of the following parts for sale or lying around and are happy to part with for cash...(this may be a completely aspirational list)
- Flywheel - 164T 50oz offset - mounting a 5.0 Windsor with top loader bellhousing.
- 11 inch clutch and pressure plate - if not too worn!
- Engine frame mounts for 65/66 - preferably 66.
- Engine mounts
- Clutch and slave cylinder
- top loader bellhousing fork
- 4 bolt crank pulley - dual rung
- Fan and spacer
- fuel pump
Can't think of anything else at the moment so I may add to this list.
Tony
Re: Wanted: parts for v8 conversion - 65 Mustang
« Reply #1 on: February 15, 2022, 09:03:58 pm »
Hey Tony,
What about a nice shiny used Worley radiator with shroud and 16” thermo fan.
It has the correct inlet and outlet for a Windsor 5.0L
I’m having a clean up and would like to do a deal.
Email me for photos if interested, I can’t post photos with this new iPad.
phildrury59@gmail.com.
Offline Megzee67
  • Name: Michael
  • Car: 1967 Mustang Coupe
« Reply #2 on: February 15, 2022, 09:28:13 pm »
Hello Mr.65 FB,
For your engine mounts I highly recommend a set of TUFF Mounts
Aussie made and a great product.....especially for a new V8 installation.
https://www.tuffmounts.com.au/product/engine-mounts/tuff-mounts-engine-mounts-for-mustang-cougar-early-falcon/
Bit on the hexy side, but good value none the less.
Offline 65 Fastback
« Reply #3 on: February 18, 2022, 10:25:14 pm »
Thanks Phil and Megzee,
Since I posted I have a radiator, engine frame mounts and engine mounts.
I also have the crank pulley and I’m going to go the way of a hydraulic throw out bearing so no need for a slave cylinder.
Still chasing a clapper starter motor to mount to cast iron bell. Preferably pick up Melbourne??
