Trans cooler
Author Topic: Trans cooler  (Read 3707 times)
Offline Dingo80
Trans cooler
« on: November 17, 2021, 10:42:07 pm »
Guessing it may be a differing of opinion, but I am about to plumb my trans cooler for a mild C4 (shift kit and 2500 stall). Question is, do you plumb through radiator also or just run remote trans cooler and if so which first? I live in Perth so it is not cold, ran a trans cooler only for over 10 years but am going through rebuild so want to do it right and now.
Re: Trans cooler
« Reply #1 on: November 18, 2021, 06:42:33 am »
Hey dingo,
You should run through the radiator first, cool a bit and then finally cool in new cooler.
