Autolite Distributor Identification-Help
Author Topic: Autolite Distributor Identification-Help  (Read 2018 times)
Offline Tiny
  • Car: 66 GT Coupe
« on: August 24, 2021, 12:33:39 pm »
Hi all need some help re identification of this distributor. First thing is that the details on the upper side of the distributor show the number C7OF-12127-B with a build date of 7A 10. The neck of the distributor shows the Identification as C7OF-12131-A. Why the two different Identification Numbers on the distributor and which one do I refer to when trying to determine just exactly what I have.
Also the Distributor has dual points. Is this correct or has someone added a dual point base plate? I thought all dual point distributors didn't have a vacuum advance option but this one does.
Can you assist.
67 390 GTA Coupe with Vinyl Roof
PS, A/C
Offline NOSMustangSupplies
Re: Autolite Distributor Identification-Help
« Reply #1 on: August 24, 2021, 12:50:04 pm »
application is a 1967 Ford Mustang with 289 2v with automatic transmission and a january 10th 1967 date code
regards
PHILL BERESFORD
0412 455049
Offline Tiny
  • Car: 66 GT Coupe
« Reply #2 on: August 24, 2021, 04:05:43 pm »
Thanks Phill, is it correct that it's a Dual point and which number out of the two should it be referred to as.
cheers
PS, A/C
« Reply #3 on: August 24, 2021, 04:14:46 pm »
no not/never a dual point .  previous owner has done modifications to it......
C7OF-12127-B
Regards
PHILL BERESFORD
0412 455049
Offline Tiny
  • Car: 66 GT Coupe
« Reply #4 on: August 24, 2021, 04:27:06 pm »
Cheers, thanks Phil
Mark
PS, A/C
« Reply #5 on: August 24, 2021, 05:06:01 pm »
the 12131A number will be the casting number of the generic part, whereas the stamped 12127B part number shows the specific use and specification of the parts installed.
Dual points plate was added it appears, most of the early dual points distributors didn't have vacuum advance, but they were made with a vacuum advance later into the late '60's/early '70's
