Seat belts 66 Coupe
Author Topic: Seat belts 66 Coupe  (Read 40988 times)
Offline Hompas
  • Car: 66 Coupe
Seat belts 66 Coupe
« on: May 06, 2021, 02:43:45 pm »
Hi All,
Newbie to the world of Mustangs here, I have a 66 Coupe and need to put seatbelts in. I assume that originally lap sash style belts were used in the front but for piece of mind and safety I was looking at putting in 3 point seatbelts. If you have put them in, where have you mounted them in the roof or under the rear window?
Many Thanks
Re: Seat belts 66 Coupe
« Reply #1 on: May 06, 2021, 03:01:47 pm »
Hi Hompas,
I was thinking the same thing a few years ago, I put in four point race harnesses and they look great but are stupidly complicated to get into! They're for sale if anyone wants them!
I've gone back to the original lap belts, but am very interested in what people come up with!
« Reply #2 on: May 06, 2021, 04:28:02 pm »
My three point belts are mounted under the window line on the B pillar, as per this
https://www.youtube.com/watch?v=DC6Uk5g9y6o
I got the mounting kit from CJ's and the Australian complianced belts from https://www.seatsafe.com.au/, who were very helpful in making sure I ordered the right thing. You have to pay particular attention to the angle of the retractor.
To head off a question I'm often asked, no they don't slip of your shoulder.
« Reply #3 on: May 07, 2021, 06:51:53 pm »
Hey Geoff,
Just watched this and I'm sold, seems like a great fit, I'll fit one in time! :thumb:
Offline Megzee67
  • Name: Michael
  • Car: 1967 Mustang Coupe
« Reply #4 on: May 07, 2021, 07:10:43 pm »
Hi Phil,
I ordered an AGI 4 point roll cage for my 67 and your 4 point belts would suit the mounts perfectly.
How much do you want for your set?
Do they have a certified expiry period.
Mike
Offline Hompas
  • Car: 66 Coupe
« Reply #5 on: May 11, 2021, 01:35:03 pm »
Thanks for your reply's, Geoff289 Thanks for the link. Looks nice and neat and not too much mucking around.
« Reply #6 on: May 11, 2021, 05:18:57 pm »
Hi Phil,
Mike
Hey Mike,
That's one nice car, there's nothing like old model race cars!!! :omg: :coolpic:
Raw muscle!,,
« Last Edit: May 11, 2021, 05:28:19 pm by AussiePhil »
Offline Megzee67
  • Name: Michael
« Reply #7 on: May 11, 2021, 09:01:13 pm »
Hi Phil,
Yep, cool car and great story behind it.......Holman/Moody build from the late 60's....I posted a link on the full story a few months ago....great read......
Hence, I have changed my build plan to replicate the low, wide TransAm look...Now trying to tuck 15 x 8's on the front end..
Plus, just scored a set of 4 point harnesses from you know who.. :grin:
It's all coming together....
« Reply #8 on: May 12, 2021, 01:18:45 pm »
As I often say, if I can do it anyone can. Bit psychologically daunting drilling holes in your car.
Couple of other bits of info from my experience of fitting them. Firstly, be very careful about the placement of the holes for the retractors on the floor. On mine they ended up a little too close for comfort to the rear seat which came within a feeler guage of stuffing up the angle on the retractor which as I said before is very important for them to actually retract properly.
Secondly, the CJ kit (may be Scott Drake, can't remember, but I got it from CJ's) provides for a threaded stud on the "B pillar" with the belt secured to this with a nylock nut. The belts I got, however, are intended to be used with a thin headed bolt into a captive nut. They come with little triangular plastic covers that then slide up over the fitting making it all look nice and neat. These covers wouldn't go over the stud and nut in my set up. I just got some stainless dome nuts to put on top of the nylocks to tidy things up, looks reasonably neat and in my view anyway looks more period correct than the plastic covers would anyway.
Offline Gallop
« Reply #9 on: May 13, 2021, 12:47:35 pm »
I will start be saying I could be wrong.
I thought in Aust the seat belt anchor point had to use a bolt with a specific thread size and diameter that then threads into a nut.
« Reply #10 on: May 13, 2021, 01:00:32 pm »
Hey Geoff,
Great video!
Your Quote; Bit psychologically daunting drilling holes in your car.
Yes, I was a bit surprised seeing that big drill going through, could have damaged things and paint work!
I would make a spigot and start with a smaller drill, then get bigger to suit drilled from outside the car!
Cheers Phil
« Reply #11 on: May 13, 2021, 04:09:41 pm »
I don't pretend to be any sort of expert about either engineering or legalities. I just shared how I went about replacing the dubious lap belts in mine with three point retractables. Up to others whether they go down the same path.
Yes. The retractors need to be positioned well back so as not to compromise seat adjustment. Not only practical but an ADR requirement IIRC.
One comment, and this came from a medical opinion I heard back when I upgraded my '67 FB from factory lap belts to 3 point inertia reels.
Fixing the seatbelt to the structure below the side window - as in that youtube video - is all very well and neat, but it does mean that the seatbelt angles down off the users' shoulders to that point. Meaning that in an impact the user's skeletal system is possibly pulled downwards not just restrained. Which can't be good.
Hence I used the roof rail for the 3rd fixing, in the very same location as Ford did themselves when they installed 3-point belts in the '68 cars.
My 2c worth anyway.
I have also read that but I've also read that the "B pillar" is way stronger than the roof in these old cars. Modern cars tend to have higher waist lines than old Mustangs but some modern convertibles must  have the top mount under the window line. My partner had a VW Eos, hard top convertible, for many years. She's short enough that the top mount was above her shoulder but when I drove it the top mount was below my shoulder line. Someone will be able to tell us what the go is with current Gen 6 Mustang convertible seat belts.
I also note that four or more point racing harnesses typically have the over the shoulder straps secured behind the driver and below the shoulder line.
See above. The Aussie belts had the same diameter hole as the CJ stud, don't know about the thread pitch. If you were keen you could easily make up a plate and weld a captive nut to it and use the bolt that came with the local belt. I actually thought about doing this when I realised the plastic cover wouldn't fit but decided my welding wasn't really something I wanted to rely on for something like seat belts.
Hey Geoff,
Great video!
Cheers Phil
Too right Phil! That's what I did, also taped up the drill site
« Reply #12 on: May 13, 2021, 05:15:05 pm »
They have a hook on the seat to prevent the belt from sliding down below the shoulder level.
My 66 has the belt in the same location as you, that's why I'm going with 2018 vert seats instead of coupe ones (plus the rears don't have the split)
« Reply #13 on: May 13, 2021, 06:00:11 pm »
Cheers Dwayne. As I said earlier in this thread, mine don't slip off my shoulder. I'm just a plug gap over 6 feet. I think the physics of this is that the taller you are the more the potential for them to slip off.
One of the effects of having the belts like this is that they tend to stay tighter than the conventional ones in our other cars when you're wearing them. They don't slip off. At all, Ever.
« Reply #14 on: May 13, 2021, 07:21:42 pm »
Watching the CJ Pony video again Bill talks about 68 on Mustangs can have the top anchor point attached to the roof line!
I've felt through the my roof lining and found a slot and hole were a plate could fit in and attach an anchor point.
But that way the belt would hang down past the rear window and ruin the look of two window open look and would flap in the wind!
There for I think it would be better fitted on the non B pillar under the window line as per the video!
The possibility that the belt may slip off your shoulder is far less important to me than ruining the look of the two window open look!!!
Cheers again Phil.
« Reply #15 on: May 13, 2021, 09:05:36 pm »
The roof isn't really the right spot either. Having it up this high makes the belt cut into your neck rather than going across the shoulder. That's why things like this are often seen in pillarless applications.
https://www.seatbeltking.com.au/product/seat-belt-drop-links-for-coupe-and-two-door-vehicles-seatbelt-droplinks/
« Reply #16 on: June 03, 2021, 08:49:50 am »
Just finished off fitting my 3 point retractable seat belts on my 68 Mustang.
I ended up using the roof mounted existing slot and hole with a threaded anchor plate, a 250mm drop link and custom made anchor plates on the floor closer to the door edge. Really happy with the finish, it sits well seated and at rest!
I'll post photos later! Can't post photos of the floor anchor plates as I've put everything back together!
Cheers Phil
« Reply #17 on: June 03, 2021, 08:50:33 am »
How it sits!
« Reply #18 on: June 03, 2021, 08:53:35 am »
Roof anchor slot and hole!
« Reply #19 on: June 03, 2021, 09:44:21 am »
Hi all, finished job!
« Reply #20 on: June 03, 2021, 03:34:38 pm »
Nice job Phil. How did you secure the top mount to the car?
« Reply #21 on: June 03, 2021, 03:59:59 pm »
Hey Geoff,
I used 1" x 3/8" x 1 1/2" long steel bar with 7/16" UNF threaded hole, not longer or it won't fit into the channel through the slot.
I initially made these to slip up the door channel and anchor without drilling through the other side as Bill did in the CJ Pony video.
I just used contact cement to hold it in place! Contact cement was a bit sticky,  I'd used silastic next time.
« Reply #22 on: June 03, 2021, 04:16:50 pm »
Then I used those grandma seat belt cushions to protect the seat from the belt.
I won them once and I then found at the bottom draw! Who would think they'd come in handy!
« Reply #23 on: June 03, 2021, 05:59:01 pm »
I expected to you tell me they're riveted on or something. Glue is pretty lateral thinking. No comment on the furry things.
« Reply #24 on: June 03, 2021, 06:47:34 pm »
Hey Geoff
I did have it threaded to fit a small screw but the roof lining only folded back a little, so I didn't want to fiddle about and damage it!
Chances are it'll be another 50 years until the bolts come out again! And it won't be me!!!
The fluffy thing come in handy and fits perfectly.
