Machining a 4 lug to 5 lug diff
Author Topic: Machining a 4 lug to 5 lug diff  (Read 2303 times)
Offline 65 Fastback
« on: March 09, 2021, 04:43:52 pm »
I have 65 FB 6 cyl daily commute and want to change the rear from 4 lug to 5 lug to go with discs I’m putting on the front. I’m in no rush to swap the 6 for an 8 and 8in diffs seem hard to come by or too expensive. I saw an article on drilling the existing axels for 5 lugs (US) and wondered if anyone had bothered doing something and née a Melbourne based machine shop they would recommend or knew of a similar low cost swap.
Tony
Online AussiePhil
Re: Machining a 4 lug to 5 lug diff
« Reply #1 on: March 09, 2021, 06:29:27 pm »
Hey Tony,
You can buy four lug to five lug adaptors at a reasonable price!
Just google it!
« Reply #2 on: March 09, 2021, 07:27:10 pm »
Hey Tony,
Just google it!
Not sure those are legal here.
Online AussiePhil
« Reply #3 on: March 09, 2021, 07:50:24 pm »
Yes, your most probably right Geoff.
May just have to get an old set of axles?
Hey Tony,
Try BigAl here on the forum, he may have something or at least know!
Cheers Phil
« Last Edit: March 09, 2021, 07:59:00 pm by AussiePhil »
Offline 65 Fastback
« Reply #4 on: March 10, 2021, 06:55:07 am »
Thanks guys.
I was checking widths of diffs from other cars and note the LC/LX Torana has the same width diff (BW) as the 65 Mustang.
Online AussiePhil
« Reply #5 on: March 10, 2021, 08:32:12 am »
Hey Tony,
You'd still have to do something about the axles, they have a different stud pattern!
Added 10/3/21,
Also spring carrier width and probably universal different?
Agree with Dwyane and 67fb.
« Last Edit: March 10, 2021, 01:06:50 pm by AussiePhil »
« Reply #6 on: March 10, 2021, 09:07:10 am »
Knowing what I'm talking about isn't always a pre requisite for me chiming in but wouldn't it be pretty routine for a diff shop to cut the four lugs off and weld some five lug ones on? Doesn't seem any more challenging than shortening axles or all manner of other things a competent diff shop does.
« Reply #7 on: March 10, 2021, 09:12:08 am »
A diff shop can convert the axles over to 5-stud, but then you also need to swap out the drum brakes to 5-stud as well.
By the time you do all this, probably cheaper to just buy a used 65-66 v8 diff and just drop it in.
  • Car: 1967
« Reply #8 on: March 10, 2021, 12:26:15 pm »
Exactly. Just buy the required second-hand components, recondition as required, and simply bolt them in. Same as Mustang owners converting their I6 cars to V8s have been doing for decades.
Online AussiePhil
« Reply #9 on: March 10, 2021, 01:15:45 pm »
Hey all,
As a matter of interest I got onto US Ebay and the amount of used Mustang four lug axles available is remarkable.
Have a look at this on US Ebay,
"Mustang 4 to 5 lug rear wheel conversion"
He obviously has a jig and doesn't remove the axles!
That's how I'd do it also!
Can be done, but you decide if you'd be happy with it!
I'm a machinist and wouldn't do any worse!
Then again get into a fatality how do you stand!
« Last Edit: March 10, 2021, 01:32:08 pm by AussiePhil »
Online AussiePhil
« Reply #10 on: March 20, 2021, 06:40:41 am »
Hey 65 Fastback,
birdman has an 8" Differential for sale, not sure if 4 or 5 stud?
In for sale by private sellers!
But in Eastern Creek.
Cheers Phil
