Hi guys, bunch of left-over parts, all good and ready to use but some likely to require a cosmetic restoration with a spray can before using.
Assume all photos are NOT of the actual items, but they are photos of the SAME items - it's just a huge fag to take, upload and link so many photos here - if you want to see an actual photo of the individual item, just PM me with your mobile number and I'll get you a pic. Cheers
A good set of engine mount insulators $50, used but sound - 2 sets of these things
Used upper clutch rod, 69 CJ, $25
Full set of engine mounts, insulators and frame mounts - 67-70 big-block - $350 (SOLD)
'69 351W with A/C fan - $100. C8SE-C fan, good clutch
428CJ crank and water pump pulleys - 3-sheaves each, for P/S and SMOG equipped cars - $250: (SOLD)
428CJ Clutch and Fan - C9ZE-E and C9ZE-B $650 (SOLD)
Pair of lower alternator and smog pump brackets, 428CJ - $250 (SOLD)
1968/9/70 428CJ Smog canister bracket - $110
1968/9/70 428CJ, smog pump with non-A/C pulley - $400 turn freely and pumps well.
Feb 1969 dated 390/428 waterpump - big bearing C9 part number, rebuilt, painted Ford Corporate Blue and ready to install $250
390/428 passenger car smog tubes, with ferrules and smog valves - $250
Set of good used Adjustable FE rockers and pushrods. 1.76 ratio.
Rockers are good, adjusters are tight, shafts are new. $500
