WTB: original constant voltage regulator
Author Topic: WTB: original constant voltage regulator  (Read 3057 times)
Offline BAC
  • Name: Brian
  • Car: '71 M code auto
« on: October 05, 2020, 05:07:18 pm »
Looking for an original (mechanical style, not solid state) 5V constant voltage regulator as usually found bolted onto the back of the dash cluster.
Prefer '69-'73 but will consider earlier - let me know what you have.  :thumb:
Brian
Re: WTB: original constant voltage regulator
« Reply #1 on: October 05, 2020, 08:16:46 pm »
Hi Brian, I have one - NOS if I recall.
Offline BAC
  • Name: Brian
« Reply #2 on: October 05, 2020, 08:53:36 pm »
NOS?   :omg: Not sure if I can pay that sort of money.
PM me anyway with a price and I'll have a quiet cry...
Brian
Offline Edz
    • Checkout my car builds
  • Car: 66 Convertible V8 AODE
« Reply #3 on: October 07, 2020, 09:03:45 pm »
Why do you want a mechanical one when you can easily make a reliable, fully electronic one for $5? I converted mine while the cluster was out even though it was ok just for the heck of it so I didn't have to do it later? The mechanicals ones eventually fail due to heat and mechanics and the electronics all fit inside the original case and fit behind the instrument cluster?
If you look on Mustang Tech, go to home/tech zone/electrical and you will see the article there to help you do it. You just need a basic soldering iron and a couple of cheap parts.
this is the link but it may not work unless you are a member (free) - https://www.mustangtech.com.au/Content/cid=7.html
« Last Edit: October 07, 2020, 09:21:45 pm by Edz »
Offline BAC
  • Name: Brian
« Reply #4 on: October 07, 2020, 10:14:08 pm »
Excellent question!  It's not for use in my car, it's for a mate who's designing a digital device to correct temp gauge readings in classic cars.  He's onto the Mustang phase of his project and needs a regulator and temp gauges from various models to take measurements from.  I'm supplying a gauge pod from a '71-'73 but don't have a spare regulator.
It needs to be original as the mechanical ones behave differently to the solid state versions.
Brian
« Reply #5 on: October 08, 2020, 09:46:28 am »
Good idea. Does he need to borrow a temp gauge for a ‘69/70 tach dash?
Offline BAC
  • Name: Brian
« Reply #6 on: October 08, 2020, 01:17:14 pm »
PM sent.
Brian
