What have you done over the shutdown.
Author Topic: What have you done over the shutdown.  (Read 3902 times)
« on: August 02, 2020, 12:03:16 am »
Hi all, first of all I want to wish everyone good health and prosperity over the Covid 19 period.
I like a heap of others have been locked away for some time, some of it my own fault,  I had a bad dirt bike accident, so that kept me out of business for a while, you may have noticed that the Mustang forum has been a good friend to me over this time!
But I've been able to change the engine, gearbox and diff oils.
Made a shock tower brace.
Changed all braided rubber hoses to braided Teflon to get rid of fuel smell.
Fitted new horns, what a marathon that was fitting them right, but have to check out if the horn has a relay, seems not and all the current is running though the horn button, causing the horns not working properly?
Fitted a fuel surge tank and pump that I bought two years ago, (slack) (fuel surge problem cornering and hills under 1/2 tank).
Fit new water pump pulley.
Repaired the water leaking into the vent cowl.
Car hasn't  been out since mid April!
Anyhow she's almost ready to go again!
Hope this time hasn't been to bad for you all.
What jobs have you done!
« Last Edit: August 02, 2020, 07:57:13 pm by AussiePhil »
Offline fredm666
  • Name: federico
  • Car: 64.5 D-code - 55 Cusso
Re: What have you done over the shutdown.
« Reply #1 on: August 02, 2020, 08:04:05 pm »
Iā€™m still stranded in WA, since the 19th of March....
Not able to touch, drive or do anything on my Mustangs. My ā€˜01 Cobra vert is on its way to WA so I can drive it while here. My ā€˜64 is in the garage in Sydney and it will stay there until I will get back  :cry:
fred
Offline sms777
« Reply #2 on: August 03, 2020, 09:53:16 pm »
No pandemic in tropical North Queensland so I have been too busy fixing everyone elses cars, no time to play with my own.  :cry:
« Reply #3 on: August 04, 2020, 10:57:52 am »
Have fitted the heater to the '69
Trial fitted the lower dash - all good.
About to fit the steering column and put a wheel on it so it can be steered.
Then the engine and gearbox go in and then off for paint - hopefully in the next couple of weeks...
Black ā€˜63.5 Galaxie 4SPD fastback (just you wait...)
Offline HEVEN67
« Reply #4 on: August 04, 2020, 01:15:49 pm »
been doing nothing on the mustang but been busy completing this..... :bolt:
nearly there!
LUVhev
Offline nickd
  • MOCA Vic Member 924
  • Name: Nick
  • Car: 1965 Coupe
« Reply #5 on: August 04, 2020, 03:36:42 pm »
looking good Hev.
I have been busy cleaning and polishing. Three cars have been locked away since March and who knows how much longer.
Offline j hatzivalsamis
  • Name: jimmy hatziv
  • Car: 67 convertible
« Reply #6 on: August 05, 2020, 03:37:11 pm »
No Lock down in Darwin but fabricated a monte carlo bar all polished stainless that clears most things as the ones i looked at were cheap and nasty chrome ones.
« Reply #7 on: August 05, 2020, 03:40:07 pm »
Finished product
Offline Dingo80
« Reply #8 on: August 06, 2020, 09:55:21 am »
No lock down for me either in WA but had a couple of days off because I was sick of seeing everyone else off. I'm in mock up after media blast and rust/panel replacement. Managed to mount my vintage air evap, mounted condenser and big block radiator, make all my brake lines, mounted ignition coil, mock up MSD atomic, throttle cable and new pedal.
Hopefully shortly will be doing my fuel system, mount thermos, A/C hoses, custom exhaust, seatbelts and child anchors in rear. Getting closer to paint.
« Last Edit: August 06, 2020, 09:59:25 am by Dingo80 »
« Reply #9 on: August 07, 2020, 08:04:17 am »
Hey heven, Jim and Klye, look amazing,   :coolpic:
Offline 67FBGT
  • Car: 1967
« Reply #10 on: August 07, 2020, 12:50:49 pm »
Ditto what AussiePhil says. Great work, and clearly very productive use of your time too.
Keep those photos coming.
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
« Reply #11 on: August 09, 2020, 06:36:58 pm »
Spending up on goodies to finish this rebuild ..,
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
« Reply #12 on: August 09, 2020, 06:39:04 pm »
Pleasant afternoon playing in the shed..,
« Reply #13 on: August 09, 2020, 07:33:35 pm »
Just got all my wisdom teeth ripped out.
It's not pleasant  :tissue:
Offline 67FBGT
  • Car: 1967
« Reply #14 on: August 10, 2020, 08:10:07 am »
Just got all my wisdom teeth ripped out. It's not pleasant
So isn't that the best excuse you've ever had to go treat yourself because you've been brave? Not food obviously... something for the car perhaps?
« Reply #15 on: August 10, 2020, 10:06:35 am »
Dwayne i feel your pain , i get like that every time i have to buy parts. Ha Ha.
Offline HEVEN67
« Reply #16 on: August 11, 2020, 09:48:13 am »
Di you have any progress pics of the inner guards being replaced.
Luvhev
« Reply #17 on: August 11, 2020, 10:43:02 am »
Can't chew any solid food for 6 bloody weeks as worried my jaw will crack where the tooth and cyst were removed from.
« Reply #18 on: August 11, 2020, 06:29:46 pm »
Hi all,
I've had a bad run lately,  15 months ago I fell through my ceiling breaking 5 ribs, had a heart attack in February playing tennis and a dirt bike accident in May and broke nine ribs, shoulder blade, punctured lung, bruised sternum and damaged 2 vertebrae.
But I'm on the mend (nearly) and trying to convince my wife to keep my Yamaha WR450F.
As you get older you don't bounce like you used to! Not much recollection of the accident I think the bike must have landed on me!
Although I've had heaps of accidents this has been my worse!
Hope you've all had a better run than me, but I'm sure some may have not!
I reckon I'm ready for a ride next month!
On a more positive side I've finished off fitted an "pump in" surge tank, Submerging the Bosch 044 has quietened it a little.
Chin up, Phil
« Last Edit: August 11, 2020, 07:35:20 pm by AussiePhil »
« Reply #19 on: August 11, 2020, 07:51:27 pm »
Hey Dwayne, wish you the best! Good chance you catch up on some thick shakes if you can stand the cold.
My favourite is chocolate!
I don't mind a chocolate Sunday either!
Mmm, I think I might go to the freezer and get a almond magnum!
« Reply #20 on: August 11, 2020, 09:00:49 pm »
Bloody hell Phil, I'll stop feeling sorry for myself and be thankful I stopped riding bikes years ago.
Look after yourself too.
« Reply #21 on: August 11, 2020, 09:10:44 pm »
Thanks Dwayne,
It had to catch up with me sooner or later!
Just love the feeling of being free, watched "On any Sunday" that week and was having a great day!
Dirt bikes these days are much more forgiving so you go faster, got crossed up in a muddy paddle!
Cheers Phil
