Thx FBGT. That's a good point and something I should not dismiss. I've had the shaft straightened twice over the past 10 years once with a speedy sleeve and pressed on at least 2 or 3 bearings/seals as well. I'll also get an opinion from the guy who had it out only 6 mths ago and see what they think. I'm getting some grease on the bottom on the wheel onto the rubber, nothing on the brake linings. When I jack the car up and take off the wheel there is a noticeable wobble on the leaking side which I thought just had to be a bent shaft but if its only a bearing I should trouble shoot that. thx
