Is RTV on oil pan gasket a personal preference?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Technical - General
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is RTV on oil pan gasket a personal preference? (Read 2349 times)
Dingo80
Worked
Dingo80
on:
September 27, 2019, 03:06:05 pm »
I am about to refit my ford racing oil pan and have got a one piece rubber/metal core gasket M-6710-A351 to suit. I am finding differing information on whether RTV should be used. The general seems around the front and rear main seal but what about the rest of the gasket?
Last Edit: September 27, 2019, 07:39:35 pm by Dingo80
Logged
Clubman7
Worked
Cruising.
Car: 1966 coupe, 2016 GT.
Clubman7
Re: Is RTV on oil pan gasket a personal preference?
Reply #1 on:
September 28, 2019, 03:30:36 pm »
Recommended to put RTV where you suggested but otherwise shouldn't need it unless it isn't making proper contact.
Although i like putting a coating of aviation form a gasket no.3 on most gaskets.
Logged
Dingo80
Worked
Dingo80
Reply #2 on:
September 28, 2019, 04:51:37 pm »
Cool thanks. I do have some of the aviation form a gasket.
Logged
sms777
Worked
sms777
Reply #3 on:
September 29, 2019, 07:39:30 pm »
When you use a one piece gasket it's recommended not to use any sealent whatsoever. My recommendation is to put a dab of RTV or anything comparable arond the four corners of the sump to be sure. It worked for me for the last 20 years or so.
Logged
shaunp
GT 500
shaunp
Reply #4 on:
October 01, 2019, 09:01:21 am »
Just in the corners around the rear main cap, the center of the timing case etc, I also glue the rear cap on to the block so it cant capillary any oil.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Technical - General
