What year is my windsor ?
Author Topic: What year is my windsor ?  (Read 2750 times)
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
« on: September 05, 2019, 08:18:13 pm »
The reason I ask is I want to put an electric water pump on my 5.0 ltr roller engine but not sure which model to get cause the last peanut thought it would be a good idea to grind off the casting numbers and I don't know what year it was cast. I need to know if its pre 94 or post 94. I remember it having xxx in the valley under the manifold if that means anything. Is there a way of telling which year ?  Cheers.
Re: What year is my windsor ?
« Reply #1 on: September 09, 2019, 02:43:04 pm »
Its irrelevant, its what timing cover you will be the issue. Some 5.0 timing covers are to suit reverse direction pumps.
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
« Reply #2 on: September 09, 2019, 05:27:33 pm »
Cheers mate. I figured as much but just needed to be sure. I have both covers.  :thumb:
