63.5 Galaxie
Author Topic: 63.5 Galaxie  (Read 17309 times)
  • Car: 1969 Shelby GT500
Re: 63.5 Galaxie
« Reply #25 on: June 25, 2020, 07:49:14 pm »
Bullshit!! Pics or it didn't happen!!! :grin: :grin: :burnout: :burnout:
I see you made this evil post with post number 666
« Last Edit: September 16, 2020, 07:57:04 pm by mwizz »
Re: 63.5 Galaxie
« Reply #26 on: July 01, 2020, 12:54:39 pm »
Well - here you go!!
« Last Edit: September 07, 2020, 09:14:59 pm by jiffy »
Black ‘63.5 Galaxie 4SPD fastback (422chp/
493 clbft.)
Re: 63.5 Galaxie
« Reply #27 on: July 10, 2020, 10:28:35 pm »
Took the beast out before lockdown....
the car - not the boy... He's a monster, not a beast.
« Last Edit: September 07, 2020, 09:15:40 pm by jiffy »
493 clbft.)
Re: 63.5 Galaxie
« Reply #28 on: September 07, 2020, 09:29:01 pm »
and there - windshield trim is installed - bastard of a job, but there you go.
The last piece that "has" to be done.
493 clbft.)
Offline Macka
  • Vic member 1571
Re: 63.5 Galaxie
« Reply #29 on: September 16, 2020, 12:14:44 pm »
A good job..
Offline 69candy
Re: 63.5 Galaxie
« Reply #30 on: September 16, 2020, 07:16:31 pm »
 :bow: :bow: :bow: :bow:Very nice!!!
Re: 63.5 Galaxie
« Reply #31 on: September 16, 2020, 07:57:31 pm »
Great work
Re: 63.5 Galaxie
« Reply #32 on: March 17, 2023, 01:51:44 am »
The new engine for the Galaxie that I've been waiting for since mid 2021, if you zoom right in, you can see my name on the pistons!!
Nice shiny new Romac balancer!!
top end starts next week hopefully - original '63 427 heads, new valves, springs, rockers & pushrods.
It's been a long time coming, but the Galaxie is always waiting....
« Last Edit: March 17, 2023, 03:39:13 pm by jiffy »
493 clbft.)
Re: 63.5 Galaxie
« Reply #33 on: May 29, 2023, 12:43:17 pm »
ok - engine was on the dyno - not disappointed by the outcome but felt there might have been a few HP's left on the table. 422hp and 493lbft but only 34 degrees total.
https://youtu.be/g81CQRd5UMc
Biggest concern was the time taken to build oil pressure and how fast I lost it afterwards - I need to get to the bottom of this before it goes in....
« Last Edit: October 09, 2023, 04:30:17 pm by jiffy »
493 clbft.)
Re: 63.5 Galaxie
« Reply #34 on: October 09, 2023, 04:29:14 pm »
ok, so - update on the 427, and latest on the Galaxie...
Well - I thought I'd found the smoking gun, but I didn't.
Then, I did!
So, I pulled the oil filter adapter and had a look at the gasket surface and the adapter - on early 427 FE engines, there is an odd extra hole in the pad, NFI what it's for.
Worryingly, there is only the merest suggestion of a gasket surface between that drain hole and the channel for the oil pump, which - if it failed - could allow oil pressure to drain straight back into the oil pan.
So, there should be the oil pump hole, the oil gallery hole (for the rest of the engine) and 4 bolt holes. You can see the extra, small hole sitting there serving no discernible purpose. The oil filter adapter gasket (which is pretty shitty to be honest) only has the smallest amount of gasket between the oil channel and this hole (at about 11 o'clock), so I put a new gasket on there, and blocked the hole so it couldn't dump oil pressure there again..
But - that wasn't the issue.
So, I checked on the oil pressure relief valve at the back of the engine above the CAM. Very hard to find pics of the valve, or how it goes in, but I found this pic:
Which might be the one the engine builder used during reassembly as when I removed the plug on the back of the block, I found this:
The first thing out should have been the valve, not the spring (and there were 2 springs in there, not one) - this is how it's meant to look when reassembling:
So, with the valve and spring arranged like that, the valve was leaving the oil-bleed hole in the block (here it is on a 427 side oiler, but it's the same thing on a top oiler above the cam):
So, as a final check, I removed the big-end bearing caps for 4 & 8 and they were perfect, so as far as I'm concerned, we're off to the races and the new engine can go in once I have done the next things....
« Last Edit: October 11, 2023, 02:28:02 pm by jiffy »
493 clbft.)
Re: 63.5 Galaxie
« Reply #35 on: October 09, 2023, 04:36:36 pm »
so, over the last couple of weekends I've been getting the trusty 352 ready to pull, and (other than forgetting to pull the clutch inspection pan and the starter duuuur) it came out a treat!
Now that the engine bay is clear, the new owners of the 352 will be coming to pick it up in a couple of weeks (it's going to replace a tired old 2-barrel 332 in a '59 Tank Fairlane, so that will be a nice improvement), then the disc brakes can go in at the front, then the A/C setup, then a general clean up and then the 427 can go in.
More pics to follow soon.... (well, soon-ish, to be fair)
« Last Edit: October 09, 2023, 04:41:22 pm by jiffy »
493 clbft.)
Offline 69candy
Re: 63.5 Galaxie
« Reply #36 on: October 10, 2023, 07:00:38 pm »
you have been busy!!. Lucky to find the problem!!
Re: 63.5 Galaxie
« Reply #37 on: January 08, 2024, 04:38:30 pm »
latest project has been to replace the off-set pivot shafts used in the lower control arms:
These are the arms that were factory installed, as the suspension compresses, the shaft turns and alters the geometry. It makes the suspension plush at low speeds but vague and floaty at higher speeds.
So, I replaced them with these straight shafts made by a guy (Paul Turner) in Australia and I have to say they fitted up a treat, very well made:
I lobbed in a set of new lower control arm bushes because the ones in there appeared to be the originals and they were extremely fcuked.
I now am about to fit a disc brake conversion kit to improve the stopping power (and hopefully no more brake fade!!)
Then I'm adding a Classic Auto A/C kit (because it's bloody hot in QLD!)
and if I get all that right, then the 427 can go in and I might be able to drive it again! How good would that be?
« Last Edit: January 08, 2024, 04:40:15 pm by jiffy »
493 clbft.)
Re: 63.5 Galaxie
« Reply #38 on: February 22, 2024, 05:09:55 pm »
ok - the discs are on - and how small do they look??.
Now for the booster... (needs a clean I know...)
493 clbft.)
Re: 63.5 Galaxie
« Reply #39 on: February 23, 2024, 10:15:33 pm »
They certainly do look small in the wheel arch, but l assume you’re sticking with original rims.?
Re: 63.5 Galaxie
« Reply #40 on: February 27, 2024, 02:12:55 pm »
Nah - have to run 15's to clear Disc brakes and I think originals were 14's?
Anyway - running the chrome wheels from the photos above...
493 clbft.)
Re: 63.5 Galaxie
« Reply #41 on: April 23, 2024, 11:55:07 am »
so, brakes are in and done - I haven't bled them yet because it's entirely likely that the master/booster will have to come out for the engine to go in, so I'll likely be doing that.
The engine bay will get a bit of a clean up before then, and I have new rubber curtains that cover the front suspension about to go in....
The booster needing vacuum fed to it raised an issue I hadn't considered - where to draw the vacuum from the intake to power it...
I had a look at the manifold and the only place to draw vacuum from was a boss that hadn't been drilled yet, so I would have to remove the carbs, rockers, pushrods etc to get the manifold off so I could drill and tap it - wasn't really looking forward to that very much...
So I had a look around and figured that I would be better off removing the PCV setup (again) and drilling and tapping the side of the brass fitting that the PCV fitting screws into:
Others have done something similar and apparently there is enough vacuum as the PCV isn't in operation all the time - so: fingers crossed!!
493 clbft.)
Offline Gallop
Re: 63.5 Galaxie
« Reply #42 on: April 24, 2024, 12:54:35 pm »
I was going to suggest the use of a Boss 302 carb spacer which has a built in PCV port , then noticed your carb setup. Hydraulic hose shops will sometimes have all kinds of fitttings like the one you just made.
Re: 63.5 Galaxie
« Reply #43 on: April 24, 2024, 02:29:31 pm »
Good idea - I guess I could try two of them, I have a CJ base-plate here which I could compare to the B2 spacer. I'll have a play with the brass fitting first and see how I get on...
493 clbft.)
Re: 63.5 Galaxie
« Reply #44 on: May 15, 2024, 02:20:10 pm »
So - I decided to drill and tap the brass fitting where the PCV is connected - I would have been happier if it had screwed in a little further but it's so frigging tight that I'm happy with where it is. The fitting is in a smidge under 4 threads/turns and is very tight, so I'm confident it doesn't leak, and the fitting points in the right direction for the brake booster...
493 clbft.)
